Old 09-30-2016, 03:17 PM   #1
Water heater - Always on or only when needed?
So on my last camping trip a neighboring camper (older gentlemen in his 60s) gave me a tour of his camper. I noticed his water heater wasn't on and he said he doesn't turn in on till about an hour before he needs it. He camps by himself. He mentioned it'll save the water heater in the long run especially since they're so expensive to replace.
What about you guys? Not necessary or worth while to leave it off?
2017 Cherokee Grey Wolf Limited 26BH
kantonburg is offline   Reply With Quote
Old 09-30-2016, 03:19 PM   #2
I do what the old guy does. Don't know if he's right--haven't had mine that long--but I don't see much point in wasting the propane to keep the water warm.
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 09-30-2016, 03:24 PM   #3
Never gave it much thought. As far as use cost goes if you are running off AC that is part of your site fee. Propane is your cost. As far as longevity goes I camp a min of 50 nights a year. So it's only on 50 days out of the year. My unit at home is on 24-365. The on/off switch may wear out before the heater.
IMHO just turn it on when you get there and turn it off when you leave unless dry camping..
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 09-30-2016, 04:48 PM   #4
Cigarman's Avatar
Same here. I turn it on and leave it on. I like the convenience and would probably forget to turn it on until right before I needed it.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
Cigarman is offline   Reply With Quote
Old 09-30-2016, 05:00 PM   #5
raspivey's Avatar
I used to think that until I realized it was using more propane to heat it up between uses than just letting it maintain the heat. I just leave mine on all the time when camping.
2012 Chevy Tahoe LTZ - HD tow package
Old 09-30-2016, 06:13 PM   #6
I shut mine off at night mostly because the switch glows bright blue and annoys me when trying to sleep.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 09-30-2016, 07:16 PM   #7
Like at home, my hot water heater stays on all the time. In a FHU campground the electric hot water heater is on
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 09-30-2016, 07:23 PM   #8
blwnsmoke's Avatar
I use the electric for my hot water. Plus to remember to turn it on before showers.. or before needing to wash dishes would be too annoying and we would forget.
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 09-30-2016, 07:26 PM   #9
dukeboone's Avatar
If I'm on hookups I leave the water heater on (unless I turn the water supply off, which I do when I leave for an extended period). If I'm dry camping I leave the water heater off until I need it, it seems to heat really fast on propane, and I really don't need it to maintain the hot water all day long.
2016 Forester MBS 2401S
dukeboone is offline   Reply With Quote
Old 09-30-2016, 07:41 PM   #10
I stayed in my previous FR RV for 2 yrs straight and left it on all the time(electric) and only had one issue with it, had to replace the thermostat once. I believe it was $10.00 and 10 minutes to fix.
2015 Ram 3500 6.7 DRW
2017 Vengeance 39R12
RVDon is offline   Reply With Quote
heater, water, water heater
