Old 07-27-2016, 08:30 PM   #1
raforan's Avatar
Water heater cleanout
How often should I drain my hot water heater and low point drains? We haven't camped in 5 weeks but will be heading out again soon. The water sitting in the water heater shouldn't do any damage over a few weeks right?
2011 Coachmen Cattalina 26bh SOLD
2016 Coachmen Freedom Express 31SE
2014 Ford Expedition EL HD TOW PACKAGE
2015 Nights Camped 14
2016 Nights Camped 55 and counting
USMC 2005-2015 OIF OEF
raforan is offline   Reply With Quote
Old 07-27-2016, 08:54 PM   #2
Cigarman's Avatar
I don't drain until I winterize. Been doing it this way for years with no problems. Though on the freshwater side we use it up pretty quickly. If I was to go 4 or 5 weeks between outings I would probably drain the fresh.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
Cigarman is offline   Reply With Quote
Old 07-27-2016, 08:55 PM   #3
TURBS's Avatar
I drain my wh if it's going to sit more then 3 weeks.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-27-2016, 08:55 PM   #4
northstar1960's Avatar
Depends . if it's well water then yes it can start to smell after a week or two , sometimes less .. if it's treated city water then you should be ok for a few weeks . i always drained mine if it was going to sit more then a month . others let it go for months . you should always at least flush the tank min once a yr . i do mine twice but it's in full time use
northstar1960 is offline   Reply With Quote
Old 07-27-2016, 08:59 PM   #5
Flybob's Avatar
Fill a glass with water from the water heater. Cover it and let it sit in the RV until your next trip. Check the water. Are you comfortable drinking it?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-28-2016, 06:48 AM   #6
raforan's Avatar
Thank you everyone for the knowledge I will be draining it today
heater, water, water heater
