Old 02-06-2016, 04:06 PM   #11
bikendan's Avatar
Originally Posted by Kmsmith View Post
That did it, had the bypass turned the wrong direction. It will scald you now thanks again guys....
Glad it's fixed.
Probably the #1 easily fixed RV issue, especially after winter.
RV got winterized and no one changed it back.
Happens a lot to new owners, where the dealer failed to go over the WH bypass valve procedure or they don't un-winterize the unit before pickup.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 02-06-2016, 06:33 PM   #12
wmtire's Avatar
Glad you got it solved. Come springtime, this will be one of the most asked questions on the forums, as everyone starts dewinterizing their RV's for camping season.
I should take the opportunity and welcome you to the forums.
Not knowing your RV experience, nor your model of water heater. this FAQ could also be helpful, if you have the Suburban water heater with an outside ONLY switch for the 120 volt AC electric heating element. Many dealers neglect to go over this in a customer PDI and only explain the propane/dsi part of the water heater.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-06-2016, 06:45 PM   #13
tmfaulksr's Avatar
way to go FRF
this is one of the great reasons product sites exist.....
thanks for the info (i didn't even have a problem) haha
the faulks & prince
2012 Nissan Titan CC
Roadmaster Active Suspension, Firestone Airbags
2015 Rockwood 8289WS Diamond Pkg
2015 Puma 253FBS (sold)
2013 BMW R1200GSW
tmfaulksr is offline   Reply With Quote
Old 02-06-2016, 06:57 PM   #14
wmtire's Avatar
This is a little tidbit to file away in the back of the brain, which can also cause the same problem later in your RV life. If your RV is equipped with an outdoor shower, and has an on/off button on the shower wand itself....you must make sure that you turn the actual hot and cold water taps off when finished...and not just at the handheld wand (if equipped with an off/on button).
If you leave the taps on (but the handheld wand off). this also allows cold water to be pulled into the hot water line...when you turn on a tap elsewhere in the RV (like the shower or a sink). Basically works just like the bypass valve you just corrected.
Make sure to turn off the outdoor shower at the taps themselves.....if your wand can be turned off at the head.
Old 05-06-2016, 06:53 AM   #15
This forum is a god-send! We use it all the time and our questions are always answered quickly and correctly!
Debbie
xtranicedeb is offline   Reply With Quote
heater, water, water heater
