Old 02-06-2016, 01:43 PM   #1
Kmsmith's Avatar
Water Heater Help
I haveva new Wildwood Heritage Glen 263RL and my water is not hot. The water heater lights and when the hot water is first turned on it is hot but only kadt about 15 seconds. What is wrong ? Why wont it stay hot any longer ?
Kmsmith is offline   Reply With Quote
Old 02-06-2016, 01:45 PM   #2
wmtire's Avatar
Usually this is caused by a bypass valve being set incorrect, which is allowing cold water to mix in with the hot water.
Do you know how to gain access to the rear of your water heater (usually thru a cabinet, false panel, or similar from inside the RV) or do you have a plumbing station?
This thread may help:
Hot water heater
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-06-2016, 01:47 PM   #3
Ford Idaho's Avatar
water heater bypass.
You need it set for summer.
Old 02-06-2016, 02:00 PM   #4
Kmsmith's Avatar
Hot water heater
Yes I know how to get to it
Old 02-06-2016, 02:03 PM   #5
wmtire's Avatar
Check your valve positions, particular the bypass valve that ties the cold and hot water lines together for winterization purposes. I bet you may find the valve is in the wrong position, or not fully closed.
it's easy to confuse the position of the valve, since the water line is usually running vertical for this valve. The link I provided, as well as the diagram Ford Idaho shows above, shows how you want the valve to be. Let us know what you find, or if you can take a pic of it all to post.
Old 02-06-2016, 02:16 PM   #6
Kmsmith's Avatar
I will have to check it, i thought it was correct but it is different from my lance. I appreciate the input guys.
Old 02-06-2016, 02:36 PM   #7
wmtire's Avatar
There are actual pics in the link from post #2 here that may help you.
Old 02-06-2016, 03:51 PM   #8
Kmsmith's Avatar
That did it, had the bypass turned the wrong direction. It will scald you now thanks again guys....
Old 02-06-2016, 03:56 PM   #9
Mr. Dan's Avatar
Thanks for reporting back. Not everyone does. We like it when a plan comes together!
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 56; booked = 6
Old 02-06-2016, 03:59 PM   #10
Kmsmith's Avatar
No problem, i really appreciate it....
heater, water, water heater
