Old 05-27-2016, 10:35 PM   #1
Water Heater Problem
I recently bought a used bumper pull and I'm having trouble with the water heater. It heats fine with the electric. On propane, it never turns off. In fact, when it self lights it never goes off full flame. The relief valve started pouring water and I had to turn off the switch. The thermostat is as low as it can go.
Suburban 6 gallon 2001 model.
waltnamie is offline   Reply With Quote
Old 05-27-2016, 10:40 PM   #2
wmtire's Avatar
If it's a dual powered version (gas and electric), it also has two thermostats, one each for gas and electric. They are under the black rubber covers on the face of the water heater that say RESET.
It sounds like maybe the right hand one (the gas) is not functioning correct and thus cutting power when the water temp reaches its level.
You might could remove the cover and see if it is loose and not contacting the tank correct to sense the heat. It could also just be faulty.
They are not hard to replace, but you have to make sure you have the correct one for which power source you are replacing (either the 120 volt electric heating element, or the 12 volt propane). The two are NOT interchangeable.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-27-2016, 10:43 PM   #3
I'll give it a try in the morning.
Old 05-27-2016, 10:45 PM   #4
wmtire's Avatar
I edited my post with some pics. Let us know what you find, please.
heater, water, water heater
