Old 09-26-2016, 07:43 AM   #1
BeeGee's Avatar
Water Heater problem
This is a new 2017 unit and I'm just trying to save the trouble of a dealer visit. The water heater worked fine on propane for a couple days then on 3rd morning the water was cold. We have propane to the cook top and the fridge. No popped breakers or fuses. The water heater works fine if we switch to electric. Any troubleshooting ideas?
2012 Ford Lariat F-350 Super Duty
2014 Forest River Cherokee Wolf Pack 27 TH
BeeGee is offline   Reply With Quote
Old 09-26-2016, 07:55 AM   #2
wmtire's Avatar
Do you know what brand/model water heater you have, as there will be a difference in troubleshooting the different ones (as Forest River doesn't use the same brand in each RV they produce)?
If you have a Suburban brand, this FAQ may give you some ideas on what to check and to also make sure you are operating it correct.
http://www.forestriverforums.com/for...tml#post327988
We can troubleshoot it a lot more once the brand/model is confirmed.
2011 Flagstaff 831 RLBSS
Old 09-26-2016, 03:58 PM   #3
BeeGee's Avatar
It appears to be a Suburban D Model
Old 09-26-2016, 04:01 PM   #4
SeaDog's Avatar
check the reset buttons just below the relief valve give them a push in
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-26-2016, 07:03 PM   #5
BeeGee's Avatar
I did push the reset buttons but it didn't feel like there was anything there
Old 09-27-2016, 01:53 AM   #6
wmtire's Avatar
What you have pictured is actually a Suburban SW DE model or maybe even a SW DEL model if you have two switches inside the RV for the water heater. The D stands for the Direct Spark Ignitor (DSI) that makes the sparks to ignite the propane and the E stands for the 120 volt AC Electric heating element.
That link I provided previously in post #2 explains the operation of both the SWDE and SWDEL models.
This water heater can be powered by propane or electricity to heat the water....or both at the same time.
The propane side works independent of the electric heating element side. There are two ECO hi-limit/thermostats, each controlling either the propane or the electric heating element. These are those TWO buttons underneath the rubber covers you said you pushed to reset. The left one is for the electric heating element and the right one is for the propane.
You said the electric heating works, so we are going to negate checking stuff for it.
Here is a schematic for a SWDE model. The difference between it and a SWDEL is negligible as far as the gas side is concerned so this should suffice.
As you see there aren't but really six things involved with the propane side. You first have a 12 volt DC switch inside the rv, then a junction box where wires are tied together, a ECO (Emergency Cut Off)hi-limit/thermostat, an electronic module board, a gas valve, and the electrode which makes the sparks to ignite the propane....to heat the water.
As explained in the previous operational link, when you turn on the DSI switch inside the RV, the thermostat senses the water tank wall temperature and if it's cold enough to need to be heated then allows 12 volt DC power thru to the electronic module board, which then allows power to the gas control valve and electrode ...... which then the gas control module allows propane to flow and the electrode ignites the propane.
It does this in a cycle. Once the inside DSI switch is turned on, this starts the first cycle. If after a few attempts by the electrode to ignite the propane fails, then the system shuts off (so propane is just not free flowing unlit). It will wait a few seconds, then attempt a second and even a third cycle if needed. You can usually hear a rapid clicking as the electrode is making the sparks.
Usually, After a third failed attempt/cycle to light the propane, the system goes into a lockout mode and no further attempts to light the propane will occur, since there is probably a lot of excess propane floating around at this point, which can be dangerous. Your DSI fault light (or reset light) will now illuminate full time that is beside the DSI switch inside your RV. This tells you that the propane failed to ignite and there is a fault somewhere and the system needs to be reset.
To reset this third strike lockout, you have to turn off the DSI switch inside your RV, wait a few seconds and turn it back on...which starts the whole 3 strike cycle again. You don't want to just do this haphazardly in case there is excess propane floating around.
Now if you do also have the electric heating element on at the same time, and the electric element is keeping the water temp heated, then the thermostat for the DSI will not sense any need for heat (since the water is already heated) and thus not allow the propane to turn on (as it's not needed) since the electric heating element is maintaining the heated water.
This post is running long and I will continue in another for what to troubleshoot easily. I just wanted you to get an understanding of the process and what items can be wrong that is keeping the propane side from operating correct.
If you turn off the electric heating element, to thus let the water cool down enough (it may take a while for the temp to fall enough) for the thermostat to call for heat on the propane side, does the fault light stay on after the three cycles? You may need to test this, as this also gives a sign where to troubleshoot....which can be something real easy. Do you hear the electrode clicking too when turning on the DSI switch?
Also before we go too technical, are you handy with a multimeter?
The easiest things to check at this point is to make sure the wires/connections are firm at the gas control valve and electrode.
Old 09-27-2016, 08:38 AM   #7
BeeGee's Avatar
I will check the systems you describe and let you know the result. Thanks
Old 10-17-2016, 07:48 AM   #8
BeeGee's Avatar
Went camping and checked the system closely. So.... water in tank cold, electric element off. Made sure propane was on and turned witch on. After 3 tries the fault light came on. Strong propane smell. Let it clear and tried the whole process 3 times finally gave up and turned electric heater on. I couldn't hear the electrode clicking but I was inside. I checked the wire connections and all were tight
Old 10-17-2016, 07:52 AM   #9
northstar1960's Avatar
you need togo out when it's trying to lite you should hear it sparking . if so then it may just need the gap adjusted if no spark then the board could be bad or the ignitetor could be bad
northstar1960 is offline   Reply With Quote
heater, water, water heater
