Old 11-06-2011, 06:39 PM   #1
Water heater problem
What would cause the hot water to stop flowing and start back
Dscouts is offline   Reply With Quote
Old 11-06-2011, 06:46 PM   #2
2007 WildCat 32QBBS
05CrewDually's Avatar
What do you mean by start back? Is it a tankless? More info would help.
05CrewDually is offline   Reply With Quote
Old 11-06-2011, 08:20 PM   #3
Lottery Non-Winner
Ovair's Avatar
Are you using the water pump? Or are you using "city water" with the hose connected to the camper?
If you're using the pump, the problem may be the pump itself. But it may well be something else.
If you're using city water and the pump is turned off and you're getting intermittent flow, it could be that you have debris in the lines. Try removing the strainers at the faucet (where the water actually comes out) and see if any junk comes out.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 11-06-2011, 08:28 PM   #4
It's city water
Old 11-06-2011, 08:37 PM   #5
Check the by pass valves. If it flows for a few seconds, then gets cold, and you turn it off, wait a minute, and try again, and it works for a few seconds, and gets cold, the by pass valve is in the open position. check them all, and get them right. Do a search on her for diagrams.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 11-06-2011, 08:39 PM   #6
Lottery Non-Winner
Ovair's Avatar
Wow, I had just posted about the bypass valves and then saw that windrider had beat me to it. I have therefore edited this post. I recommend you follow windrider's advice.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Old 11-07-2011, 08:53 AM   #7
I'll look at the by pass valve. It's the only thing I can think of.
