Old 07-22-2019, 07:23 PM   #41
Wrong, not on this heater, there is no switch to run it on 120 AC, it only runs on propane
maxxtc is offline   Reply With Quote
Old 07-22-2019, 07:41 PM   #42
Originally Posted by Moblo1 View Post
There is a switch outside under the water heater exterior cover, usually under the intake pipe where you have to bend over to see it. Switch it to “on” for electric heating.
OP has a tankless WH. No tank. No electric.
Old 07-23-2019, 09:13 AM   #43
Water heater
Do you have an outdoor shower? Make sure the valves are off. If left on, it causes the hot and cold to mix and u don't get hot water.
campman2015 is offline   Reply With Quote
Old 07-23-2019, 11:14 AM   #44
You need to read the whole thread.
babock is offline   Reply With Quote
Old 07-26-2019, 05:54 AM   #45
Originally Posted by houstonstroker View Post
Did you take off the facet aerator and check for debris?
If you haven't accounted for proper flow of water from the heater (flow switch not closing) you won't get water to heat as the gas safety valve on the unit won't open. Check for voltage at the gas safety valve on the heater if none present try flushing the water tank and lines if the lines are clear you have a bad flow switch.
murrayman333 is offline   Reply With Quote
cedar creek, heater, water, water heater
