Old 12-04-2015, 12:31 AM   #21
Fulltime family RVer
Originally Posted by reddiver View Post
Make sure you have pushed the connection all the way in. Sometimes it looks like it is connected but isn't. Does put a lot of water in the water panel compartment.
I've worn that spray of water a few times!
Old 12-04-2015, 08:14 PM   #22
I have quick connects on every water connection. The only thing I screw on is a quick connect to the park water.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 12-04-2015, 08:24 PM   #23
actadh's Avatar
Thanks wmtire - already sent the links to Santa.
-Laura 2016 Shasta Oasis 18BH & 2015 Ram 1500 Hemi
actadh is offline   Reply With Quote
Old 12-04-2015, 10:25 PM   #24
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
I have quick connects on all of my hoses and on my water filter. All of my original water hoses came with plastic ends. Putting the quick connects on saves the plastic threads.
The only problem I've had is screwing a quick connection on the park hose bibb. Sometimes there is something inside that prevents the slide of the quick connect to allow engagement. I'm not sure what it is. Flow restrictor? Back flow preventer?
johng4706 is offline   Reply With Quote
Old 12-04-2015, 10:37 PM   #25
Yes some of the Park hose bibbs are very (Short Threaded) and will not allow engagement! Try to just start the QD on the Bibb the engage the Hose into it,then tighten the QD on the Bibb all the way! It works for us on the Short Thread Bibbs! Youroo!!
water
