Originally Posted by coney
I can't believe that a campground could possible have 140 psi coming out of what is a essentially a spigot. NO WAY. My whole town is under 60 psi and that is flowing through 8" mains.
It doesn’t matter what size the main is. In fact, it is common for smaller mains to have a higher water pressure than larger mains because smaller mains with a pressure equal to that of larger mains cannot supply the same volume of water. The higher pressure of a small main can produce the same volume as a larger main with a lower pressure. Some electricians (Cavie) might even understand this theory because it is very similar to the way electricity works.
It is very common for a water company to increase the pressure in their system to compensate for demand that wasn’t expected when a system was designed years ago without thought for future development. In this case, the smaller, older mains will have a higher pressure than a newer system that is built with consideration for expansion. This is exactly why the pressure range is so big in the area I work in — hundreds to thousands of newer homes have been built and added onto some of these systems that were put into the ground in the 1940s and earlier — other, newer houses are on systems that were designed and built from the 1990s to today. The houses on the older systems are those with the highest water pressure.
Bruce
