10-28-2008, 07:43 PM
ATV Junkie
Water Pressure -
Not sure if this has been posted or not (probably has - I just can't seem to find a right answer).
Is there an adjustment on the factory pump to increase either gpm or open a flow restrictor?
Really like to increase the pressure for both inside and outside shower. The current pump/setting has the pump pulsating at 1-1.5 sec intervals and never keeps a steady pressure.
Thanks for any help.
2007 FR 26DB Toy Hauler.
2005 F350 CC LWB Lariat - 6.0, 3.73. 5" MBRP Stainless Exaust. ARP Studs / EGR & Cooler Delete Terra-Grapplers.
2005 Ford Explorer XLT
1966 A-Code Mustang Coupe. Many Mods. (sold)
2006 Arctic Cat 650H1 - Many Mods.
2007 Suzuki Vinson 500. Many Mods.
3 Dogs.
Sampson: 1999-2009. R.I.P buddy. See you on the other side.
28 Nights in -'09.
10-28-2008, 08:25 PM
The problem may be flow retricters at the outlet. I removed ours in the inside shower and it is better but not like in your home.
I have also replaced the faucets on the bathroom vanity and kitchen sink with standard fixtures.
I have not tried to fix the outside shower as yet.
2009 FR All American XLR 28XT Toy Hauler
2-'05 Bombardier 400 outlanders
2000 Excursion 7.3 L, Hypertech Tunner, Jasper Monster Box trani
10-28-2008, 10:53 PM
I replaced my shower head with one from wal mart for $15 worked like a charm we have much more pressure than before even my teenage daughter with long hair can now shower in there where as with old shower head she couldnt because she couldnt get her hair rinsed out .
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
10-29-2008, 06:48 PM
The flow ristrictors on our showers were in the mixing valve. They were molded in so I had to drill them out. Much better flow now and pump runs the entire shower instead of cycling on and off. You can also adjust the pressure switch on the pump but be careful.
Gotta go campin!
10-29-2008, 07:15 PM
I noticed that my water pressure seemed to decrease as the summer went on... I first thought it was the campgrounds. It got down to a little more than a trickle. I thought of the water filter that is in my trailer (surveyor 23rks). I removed the filter and the water pressure was restored! My trailer was new this year, we stayed in it about 40 nights... I was surprised that it would clog up that quickly... Just my experiences...
10-30-2008, 07:55 PM
ATV Junkie
Interesting.
I'm going to do a little better investigating this weekend. After a long ride on the bikes it's nice to be able to rinse off outside - but that's all but impossible with the pressure. Even inside it's not enough to get the job done.
Thanks for the input folks.
3 Dogs.
28 Nights in -'09.
10-31-2008, 08:34 PM
ATV Junkie
According to the dealership - I have to get a better pump @ 100.00 bucks.
Don't mind that part so much as why there's no adjustment on the current set-up. I just need to pump to stay at a steady pressure instead of pulsating. It's at the point of not enough pressure between pulses. If it would stay steady it would be plenty - for inside anyway. Outside on the other hand needs alot more help.
Still digging...
3 Dogs.
28 Nights in -'09.
10-31-2008, 08:53 PM
Bulldog66,
Have you tried taking the cartridge out of the filter housing and running without a cartridge?
John U
2007 Rockwood 8315SS Sold 11/19
2014 Silverado 2500HD 6.0L Sold 11/19
Back on the road 10/20
2010 Born Free 22RSK
11-01-2008, 08:27 AM
If the pulsating is your problem you can either install a variable speed pump or an accumulator tank. I haven't researched the pros and cons of each so I can't comment on which would be better. I know that the accumulator tank keeps the pump from running during the night caused by those middle of the night bathroom visits.
Gotta go campin!
11-04-2008, 04:23 PM
Hello. We also had a decrease in water pressure and it turned out to be the filter. We removed during the trip and replaced later when we got home. It worked fine without the filter.
11-05-2008, 02:18 PM
The Jolly Mon
You can buy filters that have different micron ratings:
Pneumatics 101
MICRON
A measurement equal to 0.000039 inches.
In reference to filtration, the average size of the openings between pieces of the filter media are represented in microns. For example, a 40-micron filter has larger openings than a 5-micron filter. Consequently, the 40-micron filter element will let larger particles pass through the filter than the 5-micron element.
As a general rule, the smaller micron rating for a filter is better, but as with most everything, there is a trade-off. Flow capability usually drops off as the micron rating gets smaller. To overcome this, low micron-rating filters must have larger elements to keep from sacrificing precious flow.
Another factor to consider is the fact that a filter with smaller openings, such as a coalescing type, will clog quicker than a general purpose filter. Replacing filter elements can become expensive if it is happening too often. A good solution to this problem is to use a pre-filter. Always install a general purpose filter (in the 40- to 50-micron range) upstream of a coalescing filter (5-micron range or less). The general purpose filter will capture the majority of the particles before they reach the coalescing filter, thus saving the coalescing filter element from clogging too soon. Even though this requires two filters and seems expensive initially, this could mean huge savings on coalescing filter elements in the long term.
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
11-13-2008, 08:47 AM
I too have heard the factory filter is a 1 micron filter, someone suggested a 5 micron filter really helps.
07-24-2010, 04:51 PM
This week on my 2nd trip w/ the trailer the pump was pulsing a lot & not a great stream from the taps. I checked some threads on here this morning then went out to the trailer. I removed the filter (OEM WaterPur used previously for 5 days or 1 tank of water) & turned on the pump. The pump worked fine & there was decent flow from the taps.
I had purchased a couple of filters (5 micron) a while back, so I installed 1 of them. Again the pump ran fine & the flow was OK.
I'll try to keep track of how long the filter is in use before the pump starts to pulse (here's hoping it doesn't).
07-27-2010, 09:27 PM
I checked the WaterPur website & the documentation that came w/ the filter & no mention of a filtered particle size.
07-31-2010, 08:41 PM
Today I checked the flow from the showerhead since the filter change. Much better & water was flowing from all the openings. This is a vast change from when the WaterPur filter was installed. Water appeared to be only coming from half the openings.
I wish I had thought of changing the filter during the trip.
Is it possible a lot of low pressure complaints are filter related rather than pump problems?
