Old 08-24-2006, 12:37 AM   #1
water pump problem
Having just finished a 3200 mile vacation pulling my 05 Grand Surveyor I decided to pull the cover off the water pump area to see if I could determine why it was so dang noisy and see if I could do anything about it. Well, the first thing I discovered was that the water filter had no filter in it and that it had fallen off the wall having only been secured with staples on 1/8" paneling. How Dumb! Well, I glued the piece of wood to which the bracket was attached up against another wood piece that was solidly mounted and replaced the staples with screws from the outside (exposed screw heads in the trailer) and then rescrewed the four screws on the bracket, two screws on each piece of wood. Anyway it is secure now, I put a filter in and tried the pump. Everything seems to work fine and is much quieter but the pump does not shut off. Water flows fine but when you cut the water off the pump changes tone and keeps on running. There is no water running anywhere and the pump keeps on running (until I cut the switch off, of course). Any clues?
Gene Lueg
Dubach, Louisiana
Gene Lueg is offline   Reply With Quote
Old 08-24-2006, 02:14 AM   #2
Bear's Avatar
It sounds like the diafram in the pump is shot. If it won't pressure up and there are no leaks, time for a new pump.
Cheer
Bear
2000 Volvo 660 D12 425 hp 1550 torque 15 speed, Trailer Saver air ride hitch. 2006 Canadian Sport 385 RLTS 40'10" triple slide, triple axle 5'er toybox, 300 watts solar, 3000 watt inverter, Onan 5500 Marques Platnum. 1998 Polaris 300 Explorer 4X4 quad, 2003 Polaris 700 Sportsman 4X4 quad, 1994 Jeep YJ "TOAD" 3" lift 31" ProComp Mud Terrain tires
http://community.webshots.com/user/Bears319
http://www.picturetrail.com/bears319
Mission Statement : ZZZZzzzzz
Bear is offline   Reply With Quote
Old 08-26-2006, 12:49 AM   #3
Super-Duper Member
ReedMan's Avatar
Excellent reply Bear. Hard to believe on such a new trailer but would cause these symptoms. Good job.
ReedMan , Wife , Three Kids 2x 1x
2002 Flagstaff 25LB (Triple Bunks!)
2001 Chevrolet Silverado Z71 1500 LT Sport Side
ReedMan is offline   Reply With Quote
Old 09-06-2006, 01:30 PM   #4
wpwilson's Avatar
Mine has an adjustment screw to adjust the pressure. Did you check for that?
2003 F250 6.0 Diesel w/Auto trans :
2004 Flagstaff 8528BHSS
wpwilson is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Anyone Know How to Drain the Fresh Water Georgetown370 General Community Discussions 10 12-28-2006 03:48 PM
