Old 04-14-2013, 10:25 AM   #1
psgrandpa1's Avatar
Water , water...not in refrig door????
Can someone give me a clue as where to troubleshoot...NO WATER IN THE DISPENSER of refrigerator door?? 2012 Georgetown Dometic.
I checked outside panel...
Everything else on the refrig seems great.
Bryan & Vonnie MATHIESEN
Hollister MO
Retired 2011
2017 SUNSEEKER MBS 2400W
2013 HONDA FIT SPORT
psgrandpa1 is offline   Reply With Quote
Old 04-14-2013, 10:27 AM   #2
TURBS's Avatar
If there is not a shut off valve for the water dispenser then Id bet that the screen and or on/off orifice is plugged.
TURBS
Old 04-14-2013, 10:45 AM   #3
PrairieBoy's Avatar
On Dads 5th wheel there is a valve in the outside compartment for the ice maker and water supply. There should be a valve there somewhere, just need to find it.
Todd & Sheila and kids
Rouleau, Saskatchewan
2012 Surveyor SV-305
2012 Dodge Ram 1500 4X4 CC Outdoorsman
PrairieBoy is offline   Reply With Quote
Old 04-14-2013, 10:56 AM   #4
PrairieBoy's Avatar
The valve may not be in the outside compartment. It seems to me that his was actually at the point where the line tee'd off the main line near the water pump. It was accessable in the same area. It was a couple of years ago when we where trying to winterize his unit and finally realized that he never had the water turned on to his refrigerator.
Old 04-14-2013, 10:56 AM   #5
psgrandpa1's Avatar
TURBS
Where do I fund this screen...have looked...
Thanks for thoughts
Hollister MO
Retired 2011
Old 04-14-2013, 10:59 AM   #6
TURBS's Avatar
Would be on the inlet to coupler where the hose connects to the fridge.
Shut off water pump/or city water and remove hose at back of fridge .
Turn water back on and make sure you have flow .
Old 04-14-2013, 11:08 AM   #7
PrairieBoy's Avatar
Did you have water before and suddenly no water or are you trying to get it going for the first time. Should have asked this first. Like Turbo said, check for flow to the back of the fridge.
Old 04-14-2013, 11:13 AM   #8
psgrandpa1's Avatar
We do not winterized...keep in heated storage unit.
However this is first outing...and I got thirsty!!!
Ice maker is working...I can see water in the line in refrig...
Hollister MO
Retired 2011
Old 04-14-2013, 11:16 AM   #9
psgrandpa1's Avatar
As soon as hubby and dog get back from bike ride...if he has any strength left...this will bethe next thing to look at....if it doesn't infer with nap time
Beautiful day in MO...after riding out our first...and I hope only tornado experience...
Good way to get to know w fellow campers. spend and hour huddled in the bath house...
Hollister MO
Retired 2011
Old 04-14-2013, 11:17 AM   #10
PrairieBoy's Avatar
Bad switch in the water dispenser? That line may be plugged somewhere, may just need a good cleaning
Old 04-14-2013, 11:18 AM   #11
TURBS's Avatar
Has to be the solenoid or valve that opens and allows water to flow to the dispenser wether it be electrical or mechanical.
Either plugged or electrically not working.
