Old 12-27-2015, 07:02 PM   #11
Wobbles's Avatar
I just took the pick. If you look, we are under a flood warning. The audible went off last night but the display keeps going until out of the specified(NOAA) time for it, as does the flashing red light on the left that I should have included.
I researched bang for the buck and this was it.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 12-27-2015, 07:49 PM   #12
Platokidd's Avatar
http://www.amazon.com/Eton-Crank-Eme...rds=eaton+frx5
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
nights of camping
2017-67 / 16-92 / 15-73 / 14-60 / 13-33
Seasonal
Old 12-27-2015, 08:07 PM   #13
I think most any of them will work OK. You can get some pretty ritzy ones these days.
I've got a Realistic (Radio Shack) WeatherAlert that looks like an old pocket transistor radio with a pull-out extendable antenna. Three crystal channels that you can switch between. It has a stand-by mode where you can leave it on, but you won't hear the radio; but if the NWS sends out an alert, it will start beeping at you. Runs on a standard 9 volt battery or plug in wall-wart.
It's 36 yrs old and still going strong!
2011 Traverse LT, 3.6L, FWD
Old 12-27-2015, 08:19 PM   #14
I use Weather bug on my cell phone and have it set to give alerts. Has gone off several times when I have been driving for work. Also look at the accuWeather app for on your phone.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 12-27-2015, 08:54 PM   #15
X2.. The WeatherBug app can also pinpoint where you are via your phone GPS and give you alerts for your location. Live radar, lightening detector and accurate to within 30 feet. I had this tested on my property during a storm last summer. Lightening detector said it hit behind my house and sure enough found the tree.
Also have a Midland Weather radio for areas without cell phone service.
Sierra360PDEK is offline   Reply With Quote
Old 12-28-2015, 10:46 AM   #16
WDW
Look at the Cobra brand
Life is always better under a Palm tree...
2016 Mirada 35BH "Trolley"
2016 Jeep Cherokee Latitude
Previous- Jayco Greyhawk 31FK
Western NY
WDW is offline   Reply With Quote
Old 12-28-2015, 12:12 PM   #17
Weather Radio
We have the older Midland WR-100 and it works just great. Easy to set up and tune.
RussPastuch is offline   Reply With Quote
Old 12-28-2015, 12:20 PM   #18
BobHanke's Avatar
Weather Alert models are the best. You can choose between AC models with battery backup or rechargeable units that are small and easy to carry. We have simple weather channels in our CB and dash entertainment unit but must push the buttons manually to tune in. SAME (Specific Area Message Encoding) which are county specific would be nice when camped in the same location for a bit but would not be fun to reprogram multiple times a day while driving. Our iPhones have emergency notification in them which is a nice alternative. What ever you do, you need to be in range of a signal.
"Lurch" = Georgetown 2011 330TS
Jeep 2016 Cherokee
Pilot = Bob
Navigator = Xiangbing
Crew = Shikibu
BobHanke is offline   Reply With Quote
Old 12-28-2015, 01:55 PM   #19
We are considering installing a CB with NOAA channel.
http://www.amazon.com/gp/product/B00...dp_o_pC_nS_ttl
This CB/weather radio can be hand held or dash mount with external antenna. Truckers can be one of the best sources of traffic conditions while on the road. We had only a CB in our RV years ago. We got into black ice in the Chicago/Indiana area and the truckers were advising to get off the roads. If they say get off, you know the roads are bad. Obviously, we also knew the roads were bad, but not to what extent. This type of radio will also tell you if there is an accident or other delay ahead.
PenJoe is offline   Reply With Quote
Old 12-28-2015, 02:14 PM   #20
Wobbles's Avatar
PenJoe,
Start a new thread about this. I advise you to get more input prior to installation and purchase. If installing, you could wind up with some ugly permanent mounting and discover that the performance is not the best. If you choose hand held, no mess but you may still have a less than desired performance from your purchase. Lot's of gotcha's with a CB.
I won't go on about it on this thread.
Bob & Michelle
radio
