Old 06-28-2016, 11:23 PM   #21
dan-nickie's Avatar
Originally Posted by sewingcybermom View Post
I wish there was a video of this procedure. I'm afraid to tackle this, but I'm just a gal not too well versed on things like this, and I'm a visual type. Right now I take along those little tanks and it's killing me.
I do love my Q though. So much that our big grill is still in winter storage.
https://youtu.be/fjCeW5s7wvk
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 06-28-2016, 11:37 PM   #22
Blog: RVroadtripper.com
hbillsmith's Avatar
Originally Posted by dan-nickie View Post
I did one the conversion videos too but this guy's is much better
Maxxis 16" E; Ride Rite AirBags w/AirLift 1 wireless compr; Adv.Folding 4 Cover Andersen Ultimate II Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball LCI Ground Control 3.0 4pt + 2pt Elec.Rear stabilizers; 3 Slidecovers; 10ft. Portabote 6000# Dexters; mor/Ryde CRE3000 w/HD Wetbolts; King Dish Tailgater; 5hp Outboard Dual A/C; Furrion 48 Rear Camera; Champion 3100 Inverter w/Extended Run
hbillsmith is offline   Reply With Quote
Old 06-29-2016, 06:01 AM   #23
This is what I use. Just screw the adapter to your propane tank, reconnect your main propane hose and then just connect the extension hose to the adapter and your good to go. Can't get any easier.
ID:	112557   Click image for larger version
Sierra360PDEK is offline   Reply With Quote
Old 06-29-2016, 06:37 AM   #24
SYE
SYE's Avatar
Originally Posted by 172av8r View Post
Need 1/4" to 1/8" NPT coupling
https://www.amazon.com/Parker-Brass-...ng+1%2F8+1%2F4
1/4" Quick connect
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I bought this hose because the quick connect on the camper was too short for where I like to place the grill.
and you need pipe thread tape that's rated for gas/propane
You unscrew the bracket the regulator is on and then twist off the regulator. You are left with a 1/8" Male pipe.
Screw the coupler onto that (using the thread tape, of course)
then the quick connect into the coupler.
Plug the quick connect hose onto the quick connect, and the other end into the female quick connect of your camper.
Voilla!
Do you have a completed photo of this. I am on my second grill and I love the grill, but hate that I cant use it, they are both in my garage sale pile because I cannot seem to get enough gas t to keep the burners lit. I am not that smart with propane, but I am using a Stay Flow adapter on my tank and it feeds my grill, so what will happen if I remove the regulator, because then there is no regulator???
Name:	Stay Flow adapter.jpg
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79 Nights Camped 2018 4 nights reserved
SYE is offline   Reply With Quote
Old 06-29-2016, 10:30 AM   #25
172av8r's Avatar
So first, I should be clear, I adapted my grill to work with the Low pressure side of the RV propane, so I had to remove the regulator. The stay flow connects directly to the high pressure propane tank. You can't remove the regulator and still connect to the high pressure.
I don't understand why you wouldn't get enough flow, though? Does it work correctly with the green 1lb bottles? If not, maybe you have a bad regulator?
2013 Rockwood Roo 23SS
2005 Toyota Tundra 4x4 4.7L V8
172av8r is offline   Reply With Quote
Old 06-29-2016, 11:47 AM   #26
PapaE's Avatar
Originally Posted by wicked1 View Post
Ok so past weekend I had a chance to cook on a Weber Q Grill and I have to say hands down better then my Coleman LXE Roadtrip, just ordered the Grill and Stand with Wheels thru Lowe's had a 10% Coupon. I am very impressed and ordered the parts to connect it directly to the RV's low pressure connection so I don't have to carry around Propane tanks
Can't wait to get it then the Coleman goes up for sale
2016 F350 CREW 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSS
We love our new 2200 and our 2000... did like 1000 but needed more size. Did have a 2000 at home and a 1000 in trailer. Recently replaced the 1000 with a 2200 with the stand, after a cook-out w/family at campground necessitated too many batches of food. By the way, the new stands are MUCH better than the old style IMHO.
Me & the DW
2016 Coachmen Brookstone 334RE Fifth Wheel
2015 Chevy 3500HD Diesel DRW Crew Cab 4X4 LTZ
PapaE is offline   Reply With Quote
Old 06-29-2016, 12:35 PM   #27
SYE
SYE's Avatar
It seems to work fine with the 1 pounders, but I still want to use the 100.00 adapter that I have. 2 different grills, not a coincidence that it is 2 now.
Scott & Vicki
Old 06-29-2016, 01:30 PM   #28
I have the adapter hose that they sell in Home Depot to use on a 20 pound tank. I ran into the same problem. I wasn't getting enough gas to keep the entire burner lit. I thought it was the hose and bought a second hose. Finally, I realized that the problem was that the hose was not depressing the plunger in the tank enough. I had some heavy duty plastic reflective tape and I cut a round piece about 5/16" of an inch and punched a small hole in the center of it. I placed it on the end of the hose where it depresses the plunger valve in the tank and it worked! I'll post a pic in a few, but the DW has lunch ready right now!
2012 CC 36CKTS Touring Edition
[SIZE=2]2015 Ford F-350 CC DRW Lariat
Joe_GA is online now   Reply With Quote
Old 06-29-2016, 04:11 PM   #29
wicked1's Avatar
Just put mine together for our week long 4th of July trip, just using 1# tanks for this week and selling my barely 1-Year old Coleman Roadtrip
Name:	ImageUploadedByForest River Forums1467231098.762293.jpg
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 06-29-2016, 05:00 PM   #30
Hard to get a good closeup with a cell phone camera, but this is the end of the hose that attaches to the propane tank. You can see the red tape on the end. The outside dimension is more like 1/4". My DW has a hole punch that punches small holes and that is what I used for the inside hole.
This is the reflective tape that I used. It's quite tough and I didn't believe it would compress. I thought I might need to double up on the tape, but one piece was thick enough. Originally, I thought of glueing a small washer on the hose end, but this has done the trick for me. So SYE, get those grills out of the yard sale pile and enjoy them!
