06-28-2016, 10:23 PM
#21
Originally Posted by sewingcybermom
I wish there was a video of this procedure. I'm afraid to tackle this, but I'm just a gal not too well versed on things like this, and I'm a visual type. Right now I take along those little tanks and it's killing me.
I do love my Q though. So much that our big grill is still in winter storage.
https://youtu.be/fjCeW5s7wvk
Dan
2014 Berkshire 390RB-60
06-28-2016, 10:37 PM
#22
Blog: RVroadtripper.com
Originally Posted by dan-nickie
I did one the conversion videos too but this guy's is much better
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
06-29-2016, 05:01 AM
#23
This is what I use. Just screw the adapter to your propane tank, reconnect your main propane hose and then just connect the extension hose to the adapter and your good to go. Can't get any easier.
06-29-2016, 05:37 AM
#24
Originally Posted by 172av8r
Do you have a completed photo of this. I am on my second grill and I love the grill, but hate that I cant use it, they are both in my garage sale pile because I cannot seem to get enough gas t to keep the burners lit. I am not that smart with propane, but I am using a Stay Flow adapter on my tank and it feeds my grill, so what will happen if I remove the regulator, because then there is no regulator???
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
06-29-2016, 09:30 AM
#25
So first, I should be clear, I adapted my grill to work with the Low pressure side of the RV propane, so I had to remove the regulator. The stay flow connects directly to the high pressure propane tank. You can't remove the regulator and still connect to the high pressure.
I don't understand why you wouldn't get enough flow, though? Does it work correctly with the green 1lb bottles? If not, maybe you have a bad regulator?
2013 Rockwood Roo 23SS
2021Nissan Titan SV 4x4 w/integrated Tow package
06-29-2016, 10:47 AM
#26
Originally Posted by wicked1
Ok so past weekend I had a chance to cook on a Weber Q Grill and I have to say hands down better then my Coleman LXE Roadtrip, just ordered the Grill and Stand with Wheels thru Lowe's had a 10% Coupon. I am very impressed and ordered the parts to connect it directly to the RV's low pressure connection so I don't have to carry around Propane tanks
Can't wait to get it then the Coleman goes up for sale
2016 F350 CREW 6.7 PowerStroke Diesel
2015 FR Rockwood Roo 23IKSS
We love our new 2200 and our 2000... did like 1000 but needed more size. Did have a 2000 at home and a 1000 in trailer. Recently replaced the 1000 with a 2200 with the stand, after a cook-out w/family at campground necessitated too many batches of food. By the way, the new stands are MUCH better than the old style IMHO.
06-29-2016, 11:35 AM
#27
It seems to work fine with the 1 pounders, but I still want to use the 100.00 adapter that I have. 2 different grills, not a coincidence that it is 2 now.
Scott & Vicki
2021 4 reserved
06-29-2016, 12:30 PM
#28
I have the adapter hose that they sell in Home Depot to use on a 20 pound tank. I ran into the same problem. I wasn't getting enough gas to keep the entire burner lit. I thought it was the hose and bought a second hose. Finally, I realized that the problem was that the hose was not depressing the plunger in the tank enough. I had some heavy duty plastic reflective tape and I cut a round piece about 5/16" of an inch and punched a small hole in the center of it. I placed it on the end of the hose where it depresses the plunger valve in the tank and it worked! I'll post a pic in a few, but the DW has lunch ready right now!
2012 Cedar Creek 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
06-29-2016, 03:11 PM
#29
Just put mine together for our week long 4th of July trip, just using 1# tanks for this week and selling my barely 1-Year old Coleman Roadtrip
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
06-29-2016, 04:00 PM
#30
Hard to get a good closeup with a cell phone camera, but this is the end of the hose that attaches to the propane tank. You can see the red tape on the end. The outside dimension is more like 1/4". My DW has a hole punch that punches small holes and that is what I used for the inside hole.
This is the reflective tape that I used. It's quite tough and I didn't believe it would compress. I thought I might need to double up on the tape, but one piece was thick enough. Originally, I thought of glueing a small washer on the hose end, but this has done the trick for me. So SYE, get those grills out of the yard sale pile and enjoy them!
06-29-2016, 05:27 PM
#31
Hot got two of those from Home Depot that had the same problem. And they were the Weber brand so I thought they would be the best. Bought a cheaper one on Amazon that work great.
Dan
06-29-2016, 05:30 PM
#32
I was tempted to buy a hose from Walmart and see how it worked. Do you have any details on the one you got at Amazon?
06-29-2016, 05:52 PM
#33
Walmart only sells the charbroil brand and the one that goes from the propane tank to the Weber or Coleman grill works fine for $12
06-29-2016, 06:04 PM
#34
That was back in 2012. I do not remember the brand.
Dan
06-29-2016, 10:11 PM
#35
We have owned 2 Weber Q grills. The first was the big one and we needed it when camping with our 3 boys. It's 14 years old and still works great, we gave it to oldest son for his apartment patio. We then bought the smaller version for home and camping since it is usually just the two of us now. Shortly after buying the second one we had a visit from a raccoon and yes he knocked it off the table and it landed on our cement patio and broke the leg. Still works great though! We have also given the smaller one as wedding and birthday gifts for family. Highly recommend it!
2 Happy Campers & CoCoa the camping Yorkiepoo
2005 Salem LE 19FD
2009 Ford F150 Lariat
06-30-2016, 01:01 AM
#36
Thanks, I will see if I can try this
Scott & Vicki
2021 4 reserved
06-30-2016, 06:15 AM
#37
Weber Q Grill 2200
Got to try mine out last night after getting it together. Stand is a wee bit wobbly but works well, screwdriver spatula and a Miller Lite while cooking dogs and burgers, grill cooked awesome and easier to clean than the Coleman Roadtrip
06-30-2016, 06:16 AM
#38
Meant to post in previous post, sorry
06-30-2016, 07:43 AM
#39
Just a few days prior to Father's Day, we bought a Weber Spirit gas grill. What a difference in cooking from the last one we had.
Reading this thread, I looked at the accessories for it on Amazon. I'm going to order a griddle for ours. If our 5'er didn't have the bumper mounted gas grill on it, I would buy one of these Weber 2200. The reviews by thos that have bought them are awesome.
JR
2016 Forest River Heritage Glen 276RLIS
2017 Chevrolet Silverado LTZ 2500HD Duramax
Pasco, Washington
06-30-2016, 08:05 AM
#40
I just bought a 2200 about a month ago. I absolutely love it. I plumbed it into my camper tanks and it worked perfect...now if the price of beef would come down...lol..
