Old 04-01-2012, 09:26 AM   #11
Dave_Monica's Avatar
Originally Posted by rschoono289 View Post
Not sure which equalizer you have. Mine is the E2 which has head = 44 and bars(2)= 31 for total of 75. This is directly on the receiver so really isnt part of the trailer weight. In my view. If you left the head on and placed the bars in bed of truck on the #3 weigh in you should get the true tongue weight. Guess this is interpretation of tongue vs hitch weight lol
Sorry, but I don't agree. He measured the full weight effect that the camper, including the hitch, has on the truck. The hitch ratings for the truck doesn't care what is hitch weight and what is tongue weight.
Dave
Old 04-01-2012, 09:32 AM   #12
Herk7769's Avatar
Tongue weight does not change and the TV's limits are based on that.
It can be determined by using math and the two scale weights (weigh without WD bars and truck unhitched weight) OR disconnect and put front camper wheel on its own platform.
The WD weigh is just to make sure the WD is doing its job of transferring weight from the rear axle to the camper's wheels and the front axle.
The third weigh WITH bars installed is required with a WD hitch because if adjusted improperly you can overload the trucks' front axle and the camper's axles and tires.
My understanding is the hitch (and frame receiver) ITSELF (everything FORWARD of the ball) is considered truck weight. Everything AFT of the ball is considered Tongue Load.
HAM CALLSIGN - KC3FFW
Old 04-01-2012, 09:41 AM   #13
RonLynnJr's Avatar
Wow, that was pretty cheap to get all that info! That's awesome that you thought about disconnecting the WDH to see the effect. I have always been a little leery about them and wondered if they really do what they claim to do. My work has a portable set of weight scales that I can use. Once my foot heals all the way I plan on doing the same.
Ron, Tami, Annette, and Ron III
United States Coast Guard Active Duty
2011 Salem 28BHSS / 2004 Dodge 2500 Cummins
2012 reserved/camped (17/4)
RonLynnJr is offline   Reply With Quote
Old 04-01-2012, 09:45 AM   #14
MtnGuy's Avatar
Originally Posted by pg_rider View Post
The only discrepancy is the difference in total weight between #1 and #2. The only difference is that I unhooked my bars, which shouldn't have changed the total weight.
Since the CAT scales weigh in 20 increments, a 20 lb. difference is nothing to worry with. Depends on how the axles weights were "rounded" up or down.
The one other thing that hurt my head was what to do with my Equal-i-zer hitch head and bars. I removed them for the truck-only weight (#3), but wasn't sure if I should have left them attached to the truck.
To get a true tongue weight, the head assembly and bars should have stayed in place. If you removed them entirely from the truck, then that weight needs to be figured back into the equation to get your actual tongue weight. To do that, weight the head assembly and bars on your bathroom scale, and add that back to the empty solo weight.
If you threw the Equal-i-zer parts into the truck bed, then no worries.
Looks like you have the weights distributed great. Double check your axle gross weights to make sure they are all within range.
Old 04-01-2012, 09:54 AM   #15
Herk7769's Avatar
Remember the WD hitch is like a giant crow bar acting on the BALL.
It uses the hitch head as a fulcrum and levers the weight of the tongue onto the truck and camper frames. The tongue WEIGHT stays on the hitch so the trucks LIMITS do not change with a WD hitch. It just gets "distributed" more evenly for a level ride.
And ditto on "20 pounds don't mean squat"
Old 04-01-2012, 12:36 PM   #16
Newbie
pg_rider's Avatar
Here were my three weight configurations -- not sure if that helps. Also not sure if for weight #3 I should have left the hitch head and bars attached to my truck.
2012 Rockwood 2306
2007 Honda Ridgeline tow vehicle with Equal-i-zer and Prodigy P2
pg_rider is offline   Reply With Quote
Old 04-01-2012, 05:12 PM   #17
MtnGuy's Avatar
Where was the the WDH and bars during weigh-in #3 ??
Old 04-01-2012, 05:42 PM   #18
punkaccountant's Avatar
He said he took them off so I assume he meant they were off the scale. So from everything I have read, it sounds like he should have kept them on the truck for weight #3. Is that understanding correct? This stuff hurts my head too!
punkaccountant is offline   Reply With Quote
Old 04-01-2012, 07:24 PM   #19
MtnGuy's Avatar
Yes, by leaving the bars on the TV during the solo weigh-in, the TV is setup exactly like it was during the truck and trailer weigh-in without the spring bars attached. If the OPer removed the WDH, and put them in the trailer or laid them on the ground during the solo weigh-in, then the TV is no longer setup with the same weigh.....that is probably 60 lbs or so that is no longer on the TV. Instead of 5660-5180 lbs equaling 480 lbs. tongue weight, the tongue weight might be 420 lbs.......5660-5240 lbs.......or whatever the additional weight of the WDH and spring bars are.
Not a big deal with that, unless you were approaching the hitch maximum weights, or trying to decide on what weight spring bars to use. IMHO, the OPer did a great to find out all of his information. He know his weights, and how the WDH is setup (looks pretty darn good).
Kudos to pg_rider for doing the weigh-ins, and also posting here so others can see how that is done.
Old 04-01-2012, 08:28 PM   #20
Newbie
pg_rider's Avatar
Sitting on the ground next to the camper
2012 Rockwood 2306
