Old 03-15-2018, 08:31 AM   #1
Broken Toe
Cowracer's Avatar
Weighing day coming up..
So, one of the nice things about where I work is we have an 80,000 tractor trailer scale. Every truck into and out of the plant must weigh. We are kinda slammed right now, but when things ease up, I am going to haul the Rockwood up to work and spend a few hours getting it weighed out. I'm trying to figure out the most efficient plan to get all the weights with the least number of movements. FYI, this is a single element scale. It just reads overall weight. It cannot read different 'zones'
Here is my plan so far:
1) weigh front axle by itself with WDH attached.
2) disconnect WDH, weigh front axle again. W1-w2 = WDH transfer.
3) Pull forward, weigh truck with trailer attached. W3 - W2 give rear axle weight.
4) Pull forward, weigh truck and trailer combined for gross weight.
5) unhitch, weigh trailer by itself.
6) grab trailer and pull forward, set jack down off scale and weigh just the trailer axles. W5-W6 = tongue weight.
I think that gives me most of the weights a man would need. If I need to make any adjustments to the WDH, i can redo 1 and 2 until I am happy.
Anybody see anything I am missing?
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
Old 03-15-2018, 08:55 AM   #2
I believe you have a good plan. I would also add # 3.5 weight trailer axles with WDH and with out. Additionally, if your trailer is not level while towing you, may want weigh the trailer axles independently to ensure they are equal or close to equal. I wish I had access to a scale, I need to do the same thing for my new fifth wheel. My local truck stop is in the process of being rebuilt and the scale is out of service.
Happy trails.
Fireman1 is offline   Reply With Quote
Old 03-15-2018, 09:09 AM   #3
BandJCarm's Avatar
Tim
Buying lunch for the guy who runs the weight shop????
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 03-15-2018, 09:19 AM   #4
Kaadk's Avatar
Is the issue that you're your trying to do 'the least number of changes' or the 'least number of passes'?
If I were you, I'd probably do it this way:
Starting with WDH hooked up:
1) Measure front axle
2) Pull forward, measure front+rear
3) Pull forward, measure front+rear+trailer
4) Pull forward, measure trailer where truck is off scales but jack will be on scales if it drops.
5) Drop the jack and unhitch, measure trailer alone with jack.
6) Hitch back up but don't engage WDH, measure trailer without WDH
7) pull around and back over scales, measure front axle.
7) pull forward, measure front+rear
8) Drop trailer so jack is off the scale and unhitch, measure truck alone.
9) Pull forward (leaving the trailer behind) and measure only rear axle.
This should give you every possible measurement, or the means to calculate every possible measurement. Now you just need to backup over the scale, hook back up to the trailer and go home to do your math.
Old 03-15-2018, 09:20 AM   #5
Broken Toe
Cowracer's Avatar
There is no 'guy'. It's automated where the truck driver check themselves in and out.
But I'll probably buy lunch for me, so i guess that's the same thing...
Tim
2016
Rallies Attended:
Old 03-15-2018, 05:22 PM   #6
DouglasReid's Avatar
Tim
That seems a LOT of trouble and effort. If you go to a CAT scale, weigh your rig which will give you all three weights, Steering axle, Drive axle and trailer axles, the drop the trailer and reweigh just the truck, you will have all the info you need and it will take 30 minutes tops. And a written proof to boot.
2012 Wildcat Sterling 32RL, Gladiator Qr35 ST235/85R16 Load rating G, TST 507 TPMS w/ Flow-thru Sensors & Repeater, Reese Sidewinder 16K Pin Box
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Futomo Oil Drain Valve, Turbo Brake activated in Idaho Rob Heavy Tow Tune, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-15-2018, 06:05 PM   #7
Bene Gesserit Rule
Murbella7's Avatar
I agree that this is a more sensible flow. No need to continually move or hitch/unhitch if done in the right sequence. Dropping jack and unhitching, rehitching is tedious enough without multiplying the issue.
Murbella7 is offline   Reply With Quote
Old 03-15-2018, 07:43 PM   #8
jkoenig24
YES! Weights are VERY likely to differ from side to side on one (or more) axles. You really need an accurate weight for EACH wheel position. Once you have ALL that information, then you can make educated decisions re any changes that need to be made.
jkoenig24 is offline   Reply With Quote
Old 03-15-2018, 07:54 PM   #9
W5CI's Avatar
you work where trucks come and go but you never drove one, weigh your truck one day by itself. 2, take ttruck and trl with wdh pull one Axel at a time on scale and record weights. 3, disconnect wdh and repeat step 2 one Axel at a time. then do the math. good luck.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
Old 03-15-2018, 10:53 PM   #10
Smart!
Good sequence! Much more efficient.
And he's not tying up the scale while he unhitches/rehitches.
Larry
Larry-NC is online now   Reply With Quote
