Old 02-27-2016, 09:29 AM   #11
sammonilla's Avatar
Originally Posted by HONDAMAN174 View Post
I just did that upgrade:
TT suspension upgrade - Forest River Forums
Maybe this will help- sound like you need the same set up.
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Hondaman, I just checked out your link and that is exactly what I'm going to do. My question to you is why do you say to make sure the grease holes are not at the top of the shackle set up??
Scott Sammons
Woodinville Wa
GO SEAHAWKS!
2016 SILVERADO 2500HD 6.6 Duramax
2012 280BH Casscade
sammonilla is offline   Reply With Quote
Old 02-27-2016, 01:03 PM   #12
HONDAMAN174's Avatar
Lippert warned that if the holes for the grease on the bolts are at the top that there is a possibility of a high amount of contact pressure at the top and block the grease hole. If the holes are on the side the grease will come out of bolt easily.
Just glad to get away
Old 02-27-2016, 03:18 PM   #13
dieselguy's Avatar
After learning the hard way my first wet bolt install ... what Hondaman174 says is spot on. All the rest of my wet bolt installs for acquaintenances, I've made sure the grease holes are either at 3 or 9 oclock.
dieselguy is offline   Reply With Quote
