Old 05-28-2007, 04:38 PM   #11
txbobcat's Avatar
We had a similar problem. I went for a walk while the DW was asleep. I locked the door from the outside and later on called her on the Cell. She said she could not open the door. I thught OK.. What did you do now. Got back to the 5er and unlocked the door. Tried it a couple of times and it forze up on me a couple of times. Didn't know what caused the problem, so now I have some idea. Thanks for the info.
Something about the water pressure. Most RV's will handle up to 60psi. Campground water pressure can be low or high, so you need a regulator. If you get one from Wally world it will not give you a enough through put but if you order this one, Watts 263A Adjustable Regulator; range of
10-125 psi, 2" 0-160 gauge, from http://www.rvwaterfilterstore.com/Pr...Regulators.htm you can set the pressure at what ever you want. I set mine at 50psi. It gives me enough pressure to take a shower. The shotgun type have a small orifice while the 263A has a much larger orifice.
FWIW
BC
Safe travels and may God Bless
2006 F-250 PSD SRW LB, 4WD, B&W Turnover ball w/ 5th wheel Companion
2006 Forest River 29RLBS, 2 slide,
Enjoying all of the wonders God has provided for us.
txbobcat is offline   Reply With Quote
Old 05-28-2007, 05:15 PM   #12
that's a pretty slick regulator. do you have the gauge on yours?
might have to look into one of those
aintgotnun is offline   Reply With Quote
Old 05-28-2007, 05:18 PM   #13
OK duh, just reread you post. You do have the reg.
I gotta work on this reading thing
