Black water flush has a one way valve so anything on the "inside" of the valve drained into the tank.
anything on the outside dribbled out on the ground already .
My outside shower head is right next to my city water and turboflush connections. I bought a brass fitting (male 1/2 inch NPT to male hose) and a brass one way check valve that I hook to the hose wand.
The wand can reach both the city water inlet and the turboflush inlet.
With the system pressurized with pink; I just open the valve on the shower faucet with the wand hooked to the city inlet and then the turboflush inlet.
PS - again I can't take the credit for the idea or the photos. Just passing it along from the Herkbrary.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Can't take credit for that either...
Moniker hung on my computer's USB drive by a member.
Herkbrary...gotta love it !!! Thank you ..i have a blue hose with a male fitting on the end ..that may work ..it has a quick disconnect on the other end for the outside water supply..??
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
great idea! In the past for the fresh water inlet I've gone outside while the water pump is on and pressed in on the back pressure nib until pink spurts out from the pump side. This would be much easier and less messy than getting pink stuff all over me!
Tom
2004 Fleetwood Providence 38U
currently not towing a toad
As long as pink is coming out under pressure it should work.
