Old 06-17-2018, 01:58 PM   #1
what am I missing?
A bit perplexed.
I have two propane tanks on my 2618 VS.
I purchased two simple propane gauges so I can monitor the propane level. I attached one gauge to each tank then attached the original propane line to the gauges.
But with the gauges attached I don't get propane to my appliances.
I cant figure out why a gauge would affect the propane. The lines are the same, I just added a gauge....
What am I missing????
The camper is at the storage lot so no pics right now.
Steve & Suzanne and the pup Teddy
2015 Chevy 2500 HD 6.0 L 4:10
2016 Rockwood 2616 VS
pd2436 is offline   Reply With Quote
Old 06-17-2018, 02:19 PM   #2
Who Dares, Wins
doc73's Avatar
Those gages I have found are not very accurate. They need a higher flow then your camper usually flows to read correctly.
When you added them did you wrap the connections with gas tape? Maybe blocked a hole. Tanks also have a cut off incase of a major leak. If you open a cylinder too fast it might trip it. Unscrew the tank fitting to bleed the propane from the line and open the tank slowly.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-17-2018, 02:20 PM   #3
Who Dares, Wins
doc73's Avatar
Also could you have minded the line, not a lot of room in the tank holders.
2015 ChevyHD D-Max
Old 06-17-2018, 02:34 PM   #4
I checked for leaks and pinched lines. All looked good.
Old 06-17-2018, 02:34 PM   #5
A32Deuce's Avatar
Have tried 2 different gauges on my Extend a Stay, and neither one would flow enough propane. Good for your free standing grill, but not a rv.
A32Deuce is offline   Reply With Quote
Old 06-18-2018, 08:29 AM   #6
Old 06-18-2018, 08:52 AM   #7
Kaadk's Avatar
Have you tried flipping the regulator to the other tank? Tried removing one gauge at a time? It is possible you might have a bad gauge.
Old 06-18-2018, 12:03 PM   #8
I use the Mopeka bluetooth sensors for my tanks. Easier, as I they attach to the bottom of the tank with magnets, and I can just view the tank level from inside the trailer, instead of going outside. I'm actually considering getting their XL version for the 500 gallon tank for the house.
ImTravis is offline   Reply With Quote
Old 06-18-2018, 03:08 PM   #9
I don't think it is a bad gauge, as I put one on both tanks. They both showed full, I just couldn't get any propane to appliances when turned on.
Old 06-18-2018, 04:22 PM   #10
Who Dares, Wins
doc73's Avatar
Do you have a change over switch? Is it in one of the side or the other?
Remove a gage and see if you get propane.. I think you need to work back and see what you find.
Did you shut off the tanks, unscrew and retry hooking up and turning on slowly..
2015 ChevyHD D-Max
