Old 08-14-2015, 07:33 PM   #31
rsdata's Avatar
Hey spock123
you get cell service where you camp? I got ATT and don't get 1/2 bar most times...
and my receiver does not beep with signal strength... a feature my previous receiver did have...
last 4 times I setup, I was spot on with no dish adjustment necessary after the initial setup of the tripod and angling of the dish...
how do you get your tripod level? I started with a homemade tripod, but gave up fighting with it after not even getting a signal while at home, always because it was so hard to get the upright at exactly 90 degrees...
the Dishpointer (DP AR) app ($10) has been great also to find a spot thru the trees in those shady campground spots
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 08-14-2015, 10:01 PM   #32
Originally Posted by rsdata View Post
Hey spock123
I have Verizon and I get out most places I go. I don't hear too good these days but if I open a window that signal is so loud I can hear it most times outside. Direct satellite can get thur some leaves. My tripod I got in a set from Solid Signal, I'll take some pictures tomorrow, it's simple anyone can do it. All you need to know is someone that can weld a little bit
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-15-2015, 09:01 AM   #33
This is my homemade tripodClick image for larger version
Name:	ImageUploadedByForest River Forums1439647201.804469.jpg
ID:	85758Click image for larger version
Name:	ImageUploadedByForest River Forums1439647235.236240.jpg
ID:	85759Click image for larger version
Name:	ImageUploadedByForest River Forums1439647260.999148.jpg
ID:	85760Click image for larger version
Name:	ImageUploadedByForest River Forums1439647287.712326.jpg
Old 08-15-2015, 09:08 AM   #34
nomad297's Avatar
You cannot go wrong with the (TV4RV) Satellite TV for RV - Tripod - Slimline - Dish - DirectTV - RV television - Recreational Vehicles - RVers - DishTV - Satellite Dish - FTA - Tripod heavy-duty tripod setup. I don't even need to worry about watching the TV screen or listening for a tone or using a signal meter -- I aim it where I am supposed to and I go inside and make sure I hit the three satellites. I always do. Always. Sometimes I will use my wife watching the TV screen to help me get my signal as close to 100% as possible, but usually I'm just fine where I setup with no help.
Bruce
Old 08-15-2015, 09:25 AM   #35
rsdata's Avatar
spock123
very nice
I started with same tripod but did not figure out your solution of adjusting the legs that way... did you do those swedges on the pipe legs yourself?
nomad297...
yup me too... luv that tripod system... takes any guess work out of the aiming... you are always very close to the precise position, usually good enough to setup and forget about it...
kudos to TV4RV.com
did you do the LNB arm hinge mod?
2014 Shamrock 183
Old 08-15-2015, 10:14 AM   #36
This is what it looks like set upClick image for larger version
Name:	ImageUploadedByForest River Forums1439651579.896261.jpg
ID:	85763Click image for larger version
Name:	ImageUploadedByForest River Forums1439651598.504162.jpg
ID:	85764Click image for larger version
Name:	ImageUploadedByForest River Forums1439651616.146238.jpg
ID:	85765Click image for larger version
Name:	ImageUploadedByForest River Forums1439651634.253773.jpg
Old 08-15-2015, 10:46 AM   #37
WatkinsGlenCamper's Avatar
A while ago I found a deal I couldn't refuse for a new spare dish, from a Directv installer, for $25 that also included 100' of cable. I then had to figure out a stand for it. I searched the internet and found a stand that was different, inexpensive and seemed easy to make. Total cost was about $12 (for the pvc piping). Its upside down from a standard dish stand, but the angle of the receiving signal is always the same. The only difference, from a conventional setup, is the direction the dish directs the signal to the the LNB but it works like a charm. It takes only a few minutes to line it, with a compass, once the Diriectv receiver goes through its setup. I have a HD receiver at home, but use my old standard receiver in my RV at a $6.00 cost per month. Here a few photos:
ID:	85767   Click image for larger version
ID:	85768   Click image for larger version
2013 Micro-Lite 23LB
2016 Ford 4X4 F150
...and 4 Old Wooden Boats (Penn Yans)
https://www.glenphotos.com
WatkinsGlenCamper is offline   Reply With Quote
Old 08-15-2015, 10:53 AM   #38
I go RV'ing not Camping
jgourlie's Avatar
I have been using a Winegard G2 this year and have been enjoying it as I don't have to take the 15min to 1 hour to setup a dish on a tripod.
I am watching tv in less than 2 min on most occasions, can't beat that!
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 08-15-2015, 12:54 PM   #39
My setup did not cost as much as Wineguard G2 plus it only receives in SD, mine receives in HD and takes at most 15 min to set up
Old 08-16-2015, 12:59 AM   #40
benagi's Avatar
I'm a dry camper most of the time. Of all the above post, will any of these work just on battery power? 12 volt not 110 volt.
benagi is offline   Reply With Quote
antenna
