Old 08-05-2015, 10:52 AM   #1
Maron
Send a message via Yahoo to Maron
What is the best Rv Direct Tv portable antenna
Just searched 1 years worth of blogs & didn't find an answer. We are about to activate our new Direct TV receiver and would like to know what our fellow bloggers think is the best portable antenna? Please help.
Maron is offline   Reply With Quote
Old 08-05-2015, 10:58 AM   #2
TURBS's Avatar
Winegard portable.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-05-2015, 11:07 AM   #3
xman123's Avatar
i bought this setup and it was easy enough to setup and easy enough to pull in channels. The only thing you have to watch is what box you have..as this is for the newer boxes..you buy the wrong setup your stuck...
http://www.satpro.tv/RV-HD-SWM-5-Cam...lite-SL5s.aspx
OK question Time...
2016 Georgetown 335ds
Larry and Judy Crossman
Lancaster NY
xman123 is offline   Reply With Quote
Old 08-05-2015, 11:28 AM   #4
Mikegjax's Avatar
Portable antenna must be compatible with Directv to get HD channels. VUqube will work for standard channels with older receivers. Not sure if they will work with SWM.
Satpro can help.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 08-05-2015, 11:59 AM   #5
Its not portable but this is what I use. Depending on how much time you spend in your RV this one makes a world of difference when it comes to set up and take down. It isn't cheap by any means.
Winegard DIRECTV Slimeline Satellite antenna SK-3005
Middleburg Redneck is offline   Reply With Quote
Old 08-05-2015, 12:07 PM   #6
Pod2Vibe's Avatar
What model receiver do you have?
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 08-05-2015, 12:12 PM   #7
Depends on whether you want SD or HD. With a little practice, you can easily set up either a small 18" SD only dish or a larger slimline 3 HD dish attached to a tripod or similar support structure.
You level the dish support (very important for HD) and then point dish towards the SE sky, using a separate sat meter or your receiver to adjust it to the strongest signal. I can do this in less than 5 minutes, assuming there is clear view to the sky.
Whole set up costs less than $100.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-05-2015, 12:22 PM   #8
You point your dish towards the SE sky. However us folks here on the East Coast point ours towards the SW sky.
Old 08-05-2015, 12:28 PM   #9
Direct TV Setup
It will depend on witch box you are using. Example, I use a non-High Definition Box. You will have to go into the Direct TV menu and change settings to Non-SWN and 8" Round. Some boxes cannot be changed? However; If you want HD in the campground you had better know what you are doing. It requires a different Satellite for outside. For me, it is almost impossible to lock on to a HD(it takes 3 signals). In Summary, I use a manual outside satellite with a non-HD box. A satellite finder app on my iPhone to get into the vicinity of the signal, fine tune and lock down!!! fkwalter
fkwalter is offline   Reply With Quote
Old 08-05-2015, 12:30 PM   #10
[QUOTE=Middleburg Redneck;945377]You point your dish towards the SE sky. However us folks here on the East Coast point ours towards the SW skyQUOTE]
I thought you East Coast guys were never far from a cable TV hookup!!!
2015 Rockwood A128S
2010 Rockwood 2604
antenna
