Old 05-19-2015, 05:19 PM   #1
What kills the battery when not in use?
My Forest River Wildwood kills the battery within days when camper is not is use. Can't be just the carbon monoxide detector. What else could be drawing DC power? And no, I didn't leave lights or radio on.
rpatterson is offline   Reply With Quote
Old 05-19-2015, 05:23 PM   #2
markb5900's Avatar
Check that your Tv booster is off, that will kill it in a day or two.
Also, make sure your fridge is actually off.
When you open it, if the light comes on, it is not off and it will kill it in a few days also.
Don't ask me how I know of the above things. LOL
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 05-19-2015, 05:25 PM   #3
ColoradoRick's Avatar
On my Rockwood, I have a kills switch underneath the fridge. All winter, I never disconnected the battery and just used that and they kept a full charge.
I assumed they had no draw but, last camping trip, I was goofing around and discovered the slide out control does work even if totally disconnected from shore power and the kill switch was on...I was amazed! (I don't know why they would wire it like that, but it is.)
In my last trailer, I did have to disconnect the black cable off one of the batteries to ensure no draw was taking place. (Some people connect a simple switch to that.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 05-19-2015, 05:27 PM   #4
TV booster off; fridge off. Only think I can't terminate is the propane/carbon monoxide detector. But there must be something else. A fully charged deep cycle battery should not go down in 3-4 days. I even have a 2 watt solar trickle hooked up.
Old 05-19-2015, 05:27 PM   #5
buddy300's Avatar
I've left the Genisis 3 on when I was using it for surround sound on the television.
Good luck!
buddy300 is offline   Reply With Quote
Old 05-19-2015, 05:27 PM   #6
KDHfan's Avatar
NFM
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-19-2015, 05:27 PM   #7
CO2, Brakes, radio (even when off), TV Antenna booster, Anything else that is inadvertently left on. One idea that was from an old school RVer was remove all the fuses. Put a meter on the battery. Plug each fuse in individually. Check the meter for changes.
If the battery is on it's way out, you will also get the described symptoms.
The best solution is to add some form of battery cutoff switch.
madmaxmutt is offline   Reply With Quote
Old 05-19-2015, 05:29 PM   #8
My slide works on DC power, as does my stabilizers and tongue jack.
I'm leaning towards all the main DC items must draw power when not even in use.
Old 05-19-2015, 05:29 PM   #9
buddy300's Avatar
Also I put on an inexpensive battery disconnect and that took care of the problem.
Old 05-19-2015, 05:36 PM   #10
fmc
fmc's Avatar
I put an on and off switch on the 12v power to the stereo.
fmc is offline   Reply With Quote
battery
