Old 07-27-2016, 11:13 AM   #1
What kind of glue/adhesive to use?
On the top of our slide there is a piece of plastic stripping that is coming up. What adhesive should I use to glue it back down? It would be plastic to fiberglass.
It's the 3 inch wide white plastic strip that is on top of the slide that slides in under the wall when closed.
Sheripoms is offline   Reply With Quote
Old 07-28-2016, 05:22 PM   #2
Bowmanville SVT255S's Avatar
Not sure what your referring to but perhaps 3Mô Marine Adhesive Sealant 5200 will work...
2015 Ram Crew Hemi
2005 Surveyor SVT 255RS
Bowmanville SVT255S is offline   Reply With Quote
Old 07-29-2016, 07:48 AM   #3
jeff
jeff64's Avatar
Might I suggest:
Modify your profile and list your RV type and model.
A couple good pictures are worth a thousand words
I'll bet you will get all kinds of responses once the readers have a clear understanding of what you are getting at!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-29-2016, 10:22 AM   #4
I think you are talking about the strip of "Eternabond tape" not sure what you mean about plastic strip on top of the slide.
OKI Marine is offline   Reply With Quote
Old 07-29-2016, 05:36 PM   #5
That plastic strip is probably trim that makes part of the roof sealing to keep water out of the slide. Whatever you do to glue it back in place, you probably want to make sure it's properly sealed.
Phil
pmsherman is offline   Reply With Quote
Old 07-30-2016, 07:42 AM   #6
Wolverine 1945's Avatar
A contact cement type of adhesive would probably work,,, but you must follow the directions,,, contact cement must be applied to both pices,,,l and be allowed to almost completely dry !!! You may even want cover repair with Eternabond Tape ???
Wolverine 1945 is offline   Reply With Quote
Old 07-30-2016, 07:51 AM   #7
I am in this Camp, find the "Reason" also why the E-Tape camp loose! Youroo!! The OP has a "Shamrock"!
Old 07-30-2016, 07:52 AM   #8
Put a bead or Rv proflex
2015 Ram Crew Hemi
