Old 09-09-2009, 11:00 AM   #1
What kind of sewer hose support is best?
We were looking at different types of sewer hose supports and wondering which works best for most people. My husband liked the aluminum kind at first but then we read some reviews about them not holding up and that they have to kept in a straight line and besides they are expensive. I think the plastic type that you can wind around obstacles looks better. Any advice will be appreciated.
tchart is offline   Reply With Quote
Old 09-09-2009, 11:36 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
We use the Sidewinder and in most cases it works fine. However, some campsites we have stay at have their sewer connection up about 6" above ground. So the slant for drainage becomes an issue. By the time you get an elbow on the site fitting the hose is running up hill into the elbow. It makes for quite a bit of picking up the hose to get the remaining liquid out.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-11-2009, 02:22 PM   #3
powerboatr's Avatar
we use a plastic slunky thing
i have stepped on it and ran over it ad it keeps on ticking
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 09-11-2009, 02:25 PM   #4
I use the platstic slinky thing.. cheap and easy to store
2009 Surveyor 306 BH 5er
2005 Dodge ram 3500 Turbo Diesel
4 kids, two dogs and the lovely wife.
Jon Breen is offline   Reply With Quote
Old 09-11-2009, 08:46 PM   #5
NWJeeper's Avatar
I use the ground, much cheaper and I don't have to carry one more thing in the rig. I see the sewer hose supports as one of those things that was designed just to get your money but are really not all that important or all that necessary. Never had a problem NOT using a sewer hose support.
Ed & Wendy
www.nwjeepn.com
Old 09-12-2009, 09:16 AM   #6
Grape Escape
Same here Thought I might need one but found out I don't need it.
If you were to leave drain valves open all the time support would be needed but we don;t leave the valves open other than when tanks are full.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 09-12-2009, 08:09 PM   #7
Newb
Another plastic slunky user. Some places the connection goes *up* from the ground, so it's been good to have.
CDR, U.S. Navy
Me, him, 2 kids, 1 dog
F-350 (V-10) to tow
2010 Rockwood Signature Ultralite 8317RKSS
PattiPatti is offline   Reply With Quote
Old 09-12-2009, 09:07 PM   #8
Thanks alot to everyone for their ideas. I think we will wait on buying one for now and see if we really need it.
Old 09-13-2009, 07:20 AM   #9
EastlakeRoo's Avatar
Same here. I was thinking of buying one and decided to check the forum to see what other thought and came across this thread. Good thing I did, I will wait to see if I need one as well.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 09-15-2009, 11:23 PM   #10
jd-ford-hd's Avatar
I have also always just used the ground as well..!! Dump black tank first, then dump the soapy grey water and the hose is clean enough to handle while rinsing just a bit. NEVER leave the black tank valve open, the pee leaves the tank OK, but the solids just hit the bottom of the tank and stay there. Sorry to be so graphic but I see sooo many people camping with the black valve open thinking they are flushing the commode straight into a pipe as if they were at home. It dont work that way...!!
jd-ford-hd is offline   Reply With Quote
