Old 08-01-2019, 09:27 AM   #1
What the %^&% is that stench?
So a month ago I installed this and the good news is I did not fall through roof nor does the roof leak.
However...there is the horrible stench of a dead animal only in the trailer and only when there is crap in the black water tank.
I installed it and and we went a long weekend trip. After a day or so it really started to smell inside the trailer in the bathroom.
At first I thought an animal made a hole in the black cover underneath and crawled up there and died. But you only smell it from the inside. So when we left I emptied the tank and eventual the smell went away.
We left for another trip and again after a day or so the smell came back. While on the trip I bought one of these but that did not help as smell was still there
Could I have bent a pipe while on the roof. Toilet is your basic Dometic with the foot peddle flush.
UPDATE:
TT 2018 Forest River Salem Ultra Lite
Also I did not touch the pipes, could I pushed the pipe down just being on the roof?
tyler811 is offline   Reply With Quote
Old 08-01-2019, 09:43 AM   #2
llr
I suspect you may have pushed the vent pipe down, if the bottom is below the top of the liquid it can't vent.
It seems many times they are not secured properly of even too low from the factory.
It probably won't be hard to lift, the hard part is not going too far and pulling it out
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 08-01-2019, 09:45 AM   #3
Check your black tank vent. It's possible that it's plugged up. Looks like this:
Iwritecode is offline   Reply With Quote
Old 08-01-2019, 09:46 AM   #4
Head Rambler
It might help to know which RV you have.
I don't think the installation of the cover has anything to do with the odor you're getting.
Have you checked the AAV's (Air Admittance Valve) under the sinks?
Do you have standard traps or Hepvo traps?
Gotta go campin!
Old 08-01-2019, 10:02 AM   #5
Smell like #1 or #2? Have you done sniff test under the sink? Do you have a black tank flush?
2016 Siverback 33IK
Old 08-01-2019, 10:18 AM   #6
Update original post with picture of roof TT.
Sniff test not under BR sink and no BT flush, thats why I bought the sewer pipe and flush out. Which I might add before we broke camp there was only clear water coming out.
And the valves, I will have to look but I do not remember seeing those under the sink.
Definitely number 2
Old 08-01-2019, 10:24 AM   #7
FWIW, that tank flush thing that you bought isn't going to do much. The water it's spraying likely isn't getting into your black tank at all. At best it might be getting partway up the discharge pipe.
You'd probably be better getting a sprayer that you can stick down your toilet into the tank and/or filling your tank multiple times and then draining it.
Old 08-01-2019, 10:27 AM   #8
Here's a good video comparing different products.
Old 08-01-2019, 10:42 AM   #9
The only thing I can think to add is... if you now leave your roof vent open (since you installed a cover) maybe the odor from the vent pipe (on the roof and in close proximity to the vent) is being sucked into the R/V through the now open vent. Simply the installation of the roof vent cover really shouldn't have changed anything.
I also agree those drain port connection flushers really don't flush anything other than the hose. Not much makes it way into the tank. It simply all runs out the hose before ever getting to the tank as there is no way to block off what runs down the hose.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 08-01-2019, 12:11 PM   #10
Definitely number 2
Iím sorry, I looked at your flush set up and thought you had the Flush King. I used to use the Flush King when I did not have a BT flush.. with the Flush King you can shut The drain so it backfills the black tank so you can flush it that way... https://www.amazon.com/Valterra-Degr...e%2C186&sr=1-2
2016 Siverback 33IK
Old 08-01-2019, 12:43 PM   #11
Odor may have always been there and the addition of the vent cap...as one posted, is now drawing that odor into the TT. Toss out the clear plastic thing as all it does is gives you the ability to watch the clean water run down the drain hose and does nothing for the inside of your tank.
TheWolfPaq82 is offline   Reply With Quote
Old 08-01-2019, 01:33 PM   #12
stench
UPDATE:
I have to agree with Bama Rambler , The same thing happened to me and it was the AAV valve.
Look under the sink and there will be a verticle pipe coming up off the drain.
It will look like a cap for a pipe. It unscrews and you can go to lowes or home depot and pick one up for less then $10.
It would be a cheap test.
Tony4eight1 is offline   Reply With Quote
Old 08-01-2019, 02:06 PM   #13
CGK
Camping with Labs
Lots of good advice, as is the norm on this forum. I'd have thought it was the AAV, as others have suggested; but it seems too coincidental that this occurred just after you installed the MaxxAir. If the black tank vent is too close to the MaxxAir, or if the breeze is such that it is blowing from the black tank toward the MaxxAir, that could be the issue....guess I'm agreeing with TheWolfpaq82 and 5picker, as usual. Also agree with those who feel the hand-held wand through the toilet opening might work better for your black water tank wash-out. But you may still want to keep the clear elbow (be sure to plug the hose connection) so you can see the results of your handiwork!
Chris, Paula, & camping Labs, Shasta & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS
CGK is offline   Reply With Quote
Old 08-01-2019, 02:08 PM   #14
Model 300 toilet?
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is online now   Reply With Quote
Old 08-01-2019, 02:48 PM   #15
Originally Posted by retiredcamper47 View Post
Model 300 toilet?
OP said it smelled definitely like #2 not #1. That was my original thought..
2016 Siverback 33IK
Old 08-01-2019, 04:22 PM   #16
Tundra 2014
vent cover
Could you have put the new vent cover on 180 degrees from the old one? If so, could cause it to suck in odor from toilet vent. Probable not, but I have done some silly things over the years.
Tundra 2014 is offline   Reply With Quote
Old 08-01-2019, 04:27 PM   #17
If you have a Domnetic 300, call Domnetic Sanitation with your toilet model number and serial number. Several of these toilets were assembled wrong and Domnetic is replacing the affected toilets. They are also offering upgrades if they will fit your unit. The serial number is on the right side of the toilet above the foot peddle.
HMC90 is offline   Reply With Quote
Old 08-01-2019, 06:33 PM   #18
Try leaving this vent closed for a while and see if the stench is reduced or goes away.
If it does, then air flow on the roof has changed enough to bring the "fumes" back in the vent.
Perhaps installation of one of these on the tank vent(s) would solve the problem:
https://www.amazon.com/Camco-40597-B...18728745&psc=1
These work much like a "Dutch Cap" on a fireplace chimney where breezes can sometimes blow smoke back down the chimney.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 08-02-2019, 10:32 AM   #19
Did you have the stink before or after you put that thing on vent pipe ?
Kwralph is offline   Reply With Quote
Old 08-02-2019, 05:24 PM   #20
I looked and I do not have the vents in my piping. Here are pictures of under the tub and where it connects to the sink and from there it is straight drop in the grey water tank. I checked again and the smell is coming from the inside. I have closed the vent to see if it is the toilet and not the vent pulling it in from the black water tank. The picture is the kitchen sink run.Click image for larger version
ID:	211414Click image for larger version
ID:	211415Click image for larger version
