Old 08-18-2015, 06:10 PM   #1
What tool is needed
I need to replace the locking track on a draw that won't open. The screws that hold it in have a square head. What type of tool is necessary to remove and replace the broken track.
RickRed52 is offline   Reply With Quote
Old 08-18-2015, 06:29 PM   #2
fonzie's Avatar
Robertson screwdriver of proper size......
Name:	robertson screwdriver.jpg
Fonzie
Old 08-18-2015, 06:30 PM   #3
realebill's Avatar
Do you mean a square drive,instead of slotted or phillips? If so you can buy a driver with many asst bits that usually contain the 3 sizes of square drive bits.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 08-18-2015, 06:32 PM   #4
The name of the screwdrivers are called Robertsons,Lowes or Home Depot carry them and a lot of hardware stores
hardoiler is offline   Reply With Quote
Old 08-18-2015, 06:59 PM   #5
usually that screw is #2 robertson (square)
riverrat958 is offline   Reply With Quote
Old 08-18-2015, 07:35 PM   #6
Thanks!
Old 08-18-2015, 07:56 PM   #7
yes...and the one with red handle
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 08-19-2015, 11:54 AM   #8
Americans call them square headed and Canadians call them Robertsons.......Yes they are slightly different in size and tapered differently...Cdn robertsons do not fit american screws perfectly..will strip heads!!!! J
Jim in Halifax is offline   Reply With Quote
Old 08-19-2015, 03:30 PM   #9
The Robertson (Square) design is a Canadian invention ... one of the only screws that wont fall off the end of your screwdriver
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 08-19-2015, 03:36 PM   #10
have found that often a Phillips or prince-reed may fit well enough to draw a square-head out, depending on how much torque was applied during installation --
Wanderers thru Wonders
Flagstaff 21FBRS led by F150 5.4
Sun & Moon, direct us...
don1 is offline   Reply With Quote
Old 08-19-2015, 04:25 PM   #11
I was at Harbor freight yesterday and they have a whole set very inexpensive.
hifromkate is offline   Reply With Quote
Old 08-19-2015, 04:46 PM   #12
Why are the Canadians mad at us?
mike.t is offline   Reply With Quote
Old 08-19-2015, 04:49 PM   #13
We are not mad at you... just trying to help out. Lol
Patrick & Cecilia
2012 GMC Sierra 2500 HD Crewcab Duramax
2014 Forest River Tracer 2750 RBS
Honda eu3000 Generator
2015 Nights Camped : 37
2014 Nights Camped : 33
Quasipato is offline   Reply With Quote
Old 08-19-2015, 04:56 PM   #14
ACE110's Avatar
Probably true, but as many times you will need to tighten screws, I would recommend investing in a set.
2021 Forest River Vengeance Rouge Armored 371A13
2021 GMC Sierra/Denali 3500HD SRW
Anderson Ultimate 24k Hitch
ACE110 is offline   Reply With Quote
Old 08-19-2015, 07:07 PM   #15
Harbor freight is a great place to buy tools at a great price. Looking through my tool box I discovered I had a set and the #2 was the right size. This forum is a great source of information and help. Off to Lowes to see whether they can order new tracts for the draw. Disappointed a 2014 is having so many things go wrong. They are small things, thankfully inexpensive but time consuming.
Old 08-19-2015, 08:16 PM   #16
dcheatwood's Avatar
Take your old track with you. They may have the correct size in stock, or a similar one that will work. Good luck.
2018 Forester 3011 DS
Old 08-19-2015, 08:56 PM   #17
And the best set you'll ever owned !
Black
Old 08-19-2015, 10:05 PM   #18
Not mad at all ... just trying to help educate people on it ... build a deck sometime using them with a battery impact driver and you'll never go back to slot or Phillips screws again.
Check this out:
Robertson The Finest Screw on the Planet
2009 Salem PT 403FB
Old 08-19-2015, 10:06 PM   #19
Went to Lowes. They do not carry the same self locking draw tracks as advised in a earlier thread. Will need to order from an RV dealer.
Old 08-20-2015, 12:54 AM   #20
Not mad at all ... build a deck sometime using them with a battery impact driver and you'll never go back to slot or Phillips screws again.
Check this out:
And fewer dropped screws, means finishing sooner, and more time for "a cold one" (LOL)
Calgary, AB Canada
Ridenfun is offline   Reply With Quote
