Old 08-18-2015, 06:10 PM   #1
What tool is needed
I need to replace the locking track on a draw that won't open. The screws that hold it in have a square head. What type of tool is necessary to remove and replace the broken track.
RickRed52 is offline   Reply With Quote
Old 08-18-2015, 06:29 PM   #2
fonzie's Avatar
Robertson screwdriver of proper size......
Name:	robertson screwdriver.jpg
Fonzie
Old 08-18-2015, 06:30 PM   #3
realebill's Avatar
Do you mean a square drive,instead of slotted or phillips? If so you can buy a driver with many asst bits that usually contain the 3 sizes of square drive bits.
2008 rockwood signature ultra lite 8315SS[SIGPIC]
realebill is offline   Reply With Quote
Old 08-18-2015, 06:32 PM   #4
The name of the screwdrivers are called Robertsons,Lowes or Home Depot carry them and a lot of hardware stores
hardoiler is offline   Reply With Quote
Old 08-18-2015, 06:59 PM   #5
usually that screw is #2 robertson (square)
riverrat958 is offline   Reply With Quote
Old 08-18-2015, 07:35 PM   #6
Thanks!
Old 08-18-2015, 07:56 PM   #7
yes...and the one with red handle
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 08-19-2015, 11:54 AM   #8
Americans call them square headed and Canadians call them Robertsons.......Yes they are slightly different in size and tapered differently...Cdn robertsons do not fit american screws perfectly..will strip heads!!!! J
Jim in Halifax is offline   Reply With Quote
Old 08-19-2015, 03:30 PM   #9
The Robertson (Square) design is a Canadian invention ... one of the only screws that wont fall off the end of your screwdriver
2009 Salem PT 403FB
2005 Ford XLT Supercrew
Cookies & Chips is offline   Reply With Quote
Old 08-19-2015, 03:36 PM   #10
have found that often a Phillips or prince-reed may fit well enough to draw a square-head out, depending on how much torque was applied during installation --
Wanderers thru Wonders
Flagstaff 21FBRS led by F150 5.4
Sun & Moon, direct us...
don1 is offline   Reply With Quote
