Old 08-01-2016, 02:12 PM   #11
Howdy. A Progressive Industries surge protector probably 100 bucks
nephi007 is offline   Reply With Quote
Old 08-01-2016, 02:13 PM   #12
Most dealers will sell a "box of random things that you will need" and in general that box is pretty valuable your first trip out especially if you have no idea what you are doing - as I did my first trip. I bought the box and found out that I had a use for all but one item...YMMV.
Absolute necessities for your first trip at a full hookup site:
fresh water hose
water filter
Rhino-Flex Sewer Hose (with rubber gasket donut for safe measure)
Sidewinder for the sewer hose.
4 wheel chocks
link levelers
sewer tank treatment solution
RV toilet paper
toilet tank wand and a separate section of hose for black tank flush
gloves (disposable or regular work gloves)
beer
You will indeed add/subtract/upgrade/downgrade as you go along.
stantyszka is offline   Reply With Quote
Old 08-01-2016, 03:41 PM   #13
And get a big bottle of Scotch (or similar perferred libation). For medicinal use only of course.
Epat is offline   Reply With Quote
Old 08-01-2016, 03:59 PM   #14
W5CI's Avatar
Don't forget a good Brass water pressure regulator, so you won't rupture the cheap plastic water fittings in your TT
2004 Cedar Creek 30RLBS RV FlexArmor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29
2016 Days Camping 50
W5CI is offline   Reply With Quote
Old 08-01-2016, 04:58 PM   #15
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
Amazon's prices are usually better. You may want to get a surge protector hard wired. I camped near a Walmart the first two or three trips. Most of the stuff I got there. Put your trailer brand and model in the search box and see if there is information in a thread somewhere. One you camp you will understand exactly what you need. In my mind I'm happy to buy everything myself and get exactly what I need/want. Good Luck
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 08-01-2016, 05:09 PM   #16
Originally Posted by MainelyUS View Post
X2 to the above items....I would add a good (craftsman, snap on etc.) quality torque wrench and a deep socket (ours is 19mm). If your budget allows add an18v or 20v battery powered 1/2" impact "gun"....makes changing tires and any other tough nuts easier.
or you can go on the cheap, get yourself a 24" breaker bar and a 24" piece of 1" black pipe. will give you a whole lot more torque than any 1/2" battery operated torque wrench can.
ShermanD is offline   Reply With Quote
Old 08-01-2016, 05:42 PM   #17
DouglasReid's Avatar
Originally Posted by B and B View Post
Hello,
They will include a power cord, 25 ft average length. Depends on the dealer they might give you a starter kit with a 20 ft water hose, couple rolls of TP, plastic pressure regulator and dump hose, inexpensive one.
I would buy Rhino or other hi end sewer house and Y fittings. Electrical extension for you trailer, 30 or 50 amp, a good brass pressure regulator, 25 ft RV safe hose if camping in RV parks, more hose if rougher camping, outside mat as well.
X Chocks and Chock Blocks and lego blocks for levelling,
If this is a second RV you might have some of this already.
X2, that will be a good start, you will pick up more along the way.
Welcome!
Maurice, LA
2012 Wildcat Sterling 32RL
2008 Chevy Silverado 2500HD LT Diesel
TST TPMS system w/ Flow-thru sensors
2001 Cougar 281 EFS (sold)
DouglasReid is offline   Reply With Quote
Old 08-01-2016, 06:25 PM   #18
mike.t's Avatar
Many years of good times great memories and frustration with poor workmanship. But the latter is made up for because of the aforementioned times and memories.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 08-01-2016, 06:59 PM   #19
davel1971's Avatar
more like $300, but you get what you pay for. Best available.
David & Lynn
Old 08-01-2016, 07:20 PM   #20
1. Andersen #3604 Levelers. They can also be used to lift a tire off the ground (to change flat without a jack).
2. Weight distribution hitch sized to your setup.
Henboy is offline   Reply With Quote
trailer
