Old 07-31-2016, 09:17 PM   #1
What will come with the trailer?
I bought a Vengeance 377V last week and will be picking it up this Wednesday. Do trailers usually come with power cord? Sewer hoses?
Also, this trailer has a half bath, so will I need two sewer hoses and one of those Y shaped splitters?
I have a shopping cart going on Amazon but I don't want to buy things that will come with the trailer.
Thanks.
TheMohns is offline   Reply With Quote
Old 07-31-2016, 09:25 PM   #2
CANADA FROG RALLY 2017
B and B's Avatar
Hello,
They will include a power cord, 25 ft average length. Depends on the dealer they might give you a starter kit with a 20 ft water hose, couple rolls of TP, plastic pressure regulator and dump hose, inexpensive one.
I would buy Rhino or other hi end sewer house and Y fittings. Electrical extension for you trailer, 30 or 50 amp, a good brass pressure regulator, 25 ft RV safe hose if camping in RV parks, more hose if rougher camping, outside mat as well.
X Chocks and Chock Blocks and lego blocks for levelling,
If this is a second RV you might have some of this already.
B and B
2013 Rockwood 8289 Diamond Edition
GY D's/2.5 inch lift kit/Powerhouse 4 KW EFI Generator
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
2008 Golden Falcon 380PA Park Model Model
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 07-31-2016, 09:25 PM   #3
Platokidd's Avatar
Location: Home of the 2016 WORLD SERIES CHAMPIONS CHICAGO CUBS
Sewer hoses will not come with normally. You could ask for it to be thrown in on the deal.
2014 LaCrosse 323RST-TE-C
2009 CHEVY 2500HD Silverado Z71
2016- 92 nights of camping
Platokidd is online now   Reply With Quote
Old 07-31-2016, 09:32 PM   #4
davel1971's Avatar
you will want to upgrade water and sewer hoses. Probably 2 of each so you have enough. Extension cord maybe. Water filter. Pressure regulator. Progressive Industries EMS unit.
David & Lynn
Old 07-31-2016, 09:43 PM   #5
make sure they come with batteries. may come with water filter (check on it). you may want a length of coax to attach to park cable if that is what you do. good tire pressure gauge. pouch to put all the various manuals into so they are all in one place. bottle of wine to enjoy when you are soaking it all in.
CHICKDOE is online now   Reply With Quote
Old 08-01-2016, 07:10 AM   #6
The things included with the starter kit are usually junk. Buy yourself good quality supplies and keep the starter kit as a backup.
Be sure to buy a lug wrench and a jack because chances are your trailer won't come with either.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 08-01-2016, 07:35 AM   #7
Buy and Install "Roof Vent Covers" MaxAir II or Fanmate you choice I have used Both with Equal results! Some MFG Divisions have "FINALLY" came to realize we "Need/Want" these covers so we can leave the Vents OPEN anytime we want Stopped or going Down the Road! Rain or Shine! to FRF Youroo!!
Old 08-01-2016, 09:34 AM   #8
A 6in clear pipe between your dump out and your hose is nice. That way you can see when the black water tank is running clear when you flush the tank.
04 Ram 3500
07 Ram 3500
2011 Puma 295kbh
larryo is offline   Reply With Quote
Old 08-01-2016, 10:11 AM   #9
MainelyUS's Avatar
X2 to the above items....I would add a good (craftsman, snap on etc.) quality torque wrench and a deep socket (ours is 19mm). If your budget allows add an18v or 20v battery powered 1/2" impact "gun"....makes changing tires and any other tough nuts easier.
2015 Windjammer 2618VS (Hibernating)
2016 Silverado 2500HD Z71 6.0L 4:10 gears w/max. tow package
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
Old 08-01-2016, 10:22 AM   #10
Butch Wilson's Avatar
Get the basics, Hose, power adapters, socket or lug wrench, sewer hose, then take it camping for a weekend. You may like myself find out the things you need are much different from what you initally envisioned.
Butch Wilson is offline   Reply With Quote
trailer
