Old 02-28-2014, 06:54 AM   #31
Wanna Be Camper
SaskCampers's Avatar
Wash and do a good wax job, clean the interior, check the roof and clean then store till 2015.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 02-28-2014, 07:04 AM   #32
Get new tires to replace the Michelin's (LTX M/S LT225/75R16 (DOT code B3JH AKEX). Recall is for date codes (can be found right after the DOT code) ranging between 0210 and 2512.
KQ2N is offline   Reply With Quote
Old 02-28-2014, 07:06 AM   #33
KyDan's Avatar
Replace 4 original tires
replace bearings and seals and grease
inspect/adjust/replace original brake parts
I plan to have the tire store dismount the tires so I
can paint the rims and then go back for new rubber all around.
My trailer is now at the beginning of it's 7th year and is holding up well.
6 years ain't bad for tires and brakes!
I replaced bearings and seals and grease once before.
Next trailer will have alloy wheels.
I am SO tired of painting wheels!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 02-28-2014, 07:15 AM   #34
Camper Less Camping
Cajun Po-Boy's Avatar
Camp More!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-28-2014, 07:29 AM   #35
camper1999's Avatar
Wax
Re pack wheel bearings
new tires
install tv in the under belly
new shur flo pump
clean carpets
install tile back splash
timbrens on the tv
change trans fluid on tv
2011 GMC 2500HD Diesel
Old 03-02-2014, 08:49 PM   #36
larrys2112's Avatar
Gave travel trailer a good wash and wax
Upgraded my 20 lb. propane bottles to 30 lb. bottles
Installed a new black cover over the propane bottles (Changed from white)
Installed MaxxAir vent cover over front vent
Installed new toilet to replace the old style Dometic 300 with the new design that doesn't collect sewage. (Haven't camped with the new toilet yet)
2016 Rockwood Windjammer 3008W Diamond Package
2016 Toyota Tundra Double Cab 5.7L SR5 4x4
larrys2112 is offline   Reply With Quote
Old 03-03-2014, 07:01 AM   #37
jriddering's Avatar
Installing a fireplace.
Everything else is perfect.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 03-03-2014, 07:52 AM   #38
Scootdawg's Avatar
Thank you all! Being a first year RV owner I got lots of good tips. I been starting the RV and running the generator every few weeks. I am really nervous about flushing anti freeze out of the lines and hoping no lines bust. As soon as the snow melts and the artic freeze stops, I am camping.
Scootdawg is offline   Reply With Quote
Old 03-03-2014, 08:10 AM   #39
kerrlakelover's Avatar
Mfrys, don't waste too much sleep worrying about the plumbing. I think all of us, at one time or another, have taken a deep gulp on cold nights when the temps plunge and worried for a couple of minutes. But, no matter if you winterized it or if a dealer winterized it...as long as you got pink stuff coming thru all the lines, pump, and faucets/showers/toilet you should be ok.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 03-03-2014, 08:21 AM   #40
Scootdawg's Avatar
Thank you kerrlakelover for the vote of confidence!!
