Old 02-28-2016, 12:37 PM   #11
FYI-Wd 40 is fish oil
rwatson908 is offline   Reply With Quote
Old 02-28-2016, 12:38 PM   #12
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
I've used a hair dryer on high heat, Goo Gone, or WD40. They all work great.
Grampa Jim is offline   Reply With Quote
Old 02-28-2016, 01:14 PM   #13
Naptha is not "fish oil"
2015 XLR415AMP
2011 3500HD Duramax/Allison/90 Gal Aux
2015 HD Limited Low
DSQR is offline   Reply With Quote
Old 02-28-2016, 01:27 PM   #14
Be careful with heat guns, you can take paint right off if you get it too hot, goo stuff much safer and quite effective.
TARVIDSON is offline   Reply With Quote
Old 02-28-2016, 01:27 PM   #15
Ford Idaho's Avatar
What a Fish story!
Myth: WD-40® contains fish oil.
Fact: Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40®. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlie®, it just ain’t so.
WD-40 Company has taken steps to respect and conserve the environment, and encourages its users to do the same. While WD-40® can be used to help protect fishing equipment from rust and corrosion, WD-40 Company does not recommend using WD-40® to attract fish.
Old 02-28-2016, 04:44 PM   #16
The best sticker removal is a product called Contractor's Solvent. I managed 12 dealerships and had all kinds of occasions to remove stickers of all types and found that Contractor's Solvent worked the best out of all the others. They all work but this stuff works the best! It's also more pleasant in the odor dept and easier to clean up afterwords. You can get it at most better hardware stores and the big box stores.
glfillion is online now   Reply With Quote
Old 02-28-2016, 09:07 PM   #17
LinemanSeth's Avatar
Got a orange parking violation sticker on the window once and on the bottom in fine print it said to remove use rubbing alcohol. Worked great for me.
Have also used denatured alcohol.
2014 Chevy 1500 Crew Cab 5.3 4X4
LinemanSeth is offline   Reply With Quote
Old 02-29-2016, 06:27 AM   #18
Occasional campers
Solvent for sticky stuff
Originally Posted by JoyMarie View Post
When we bought our camper, the dealership had two stickers on the front of it. They removed one but left the other. What's the best way to remove it and get the stickiness off? There's dirt sticking to the camper where they removed one of the stickers and it looks awful. TIA.
If you need to remove a sticker, I would suggest a hair dryer and peeling the sticker while it's warm. I would not recommend a heat gun, because they're VERY hot and there's too much chance of damaging paint or underlying surface. For the sticky junk, I would recommend mineral spirits, lighter fluid (naptha) or Goo Gone. I normally use mineral spirits because it's relatively cheap and available at almost any hardware store; also fairly low-level odor. Lighter fluid usually has a strong odor. For either of those, remember that they're flammable! Goo Gone is good but generally is on the pricey side. For a few cases, the adhesive could be something that needs to be "cut" with alcohol (look at concentration and try fairly strong rubbing alcohol); if so, allow any hydrocarbon you've tried to dry first. Best of luck!
Ray and Ann is online now   Reply With Quote
Old 02-29-2016, 06:32 AM   #19
MilCop4523's Avatar
mineral spirits.
the left over stuff you can use to clean the old caulking before you reseal all the joints this summer
2009 Heartland Sundance 31.5 XLT bunkhouse
2013 Ford F150 XTR ECOBOOST
"Of the troops - For the troops "
MilCop4523 is offline   Reply With Quote
Old 02-29-2016, 09:14 AM   #20
3M adhesive remover works great also.
2000 SIERRA 30 ft FKSS
hondo is offline   Reply With Quote
