Old 03-23-2015, 02:03 PM   #1
What's the lowest temps to de-winterize?
Well, tomorrow is the day we have to move the TT out of indoor storage and today it decided to snow 5". This has been a very cold and snowy Winter and it looks like the cold is going to stay around for awhile. I was wondering how long we should wait to de-winterize the camper. What should the temps be?
2011 MicroLite 23LB
2012 Ram 1500 Crew Cab
zinger60 is offline   Reply With Quote
Old 03-23-2015, 02:05 PM   #2
fonzie's Avatar
Needs to be above freezing and stay above freezing.
Fonzie
Old 03-23-2015, 02:08 PM   #3
Ford Idaho's Avatar
correctamundo!
Old 03-23-2015, 02:28 PM   #4
B and B's Avatar
I removed mine from storage to get ready for our first trip in April. Getting everything ready but left pink fluid in its veins for now. We had 10 F here last night. All cleaned up and ready inside. Outside wash Wednesday hopefully, suppose to be warmer.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 03-23-2015, 02:33 PM   #5
Witch Doctor's Avatar
When it gets above 32 degrees during the day and not below that for over 6 hrs a night.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-23-2015, 03:01 PM   #6
PhoneDude 8289's Avatar
X2
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 03-23-2015, 03:08 PM   #7
When we got back from FL in Feb, we just left the EdenPure on and the furnace blower running and never winterized at all. I did pull the anode out of the water heater and let it drain and opened all the faucets. Never had anything freeze and we had some way below freezing temps over night. Inside temp stayed around 55° - 60° when I would check around 7 or 8 in the morning.
Old 03-23-2015, 04:56 PM   #8
mjones12's Avatar
That's your best answer. There are some who will tell you that your camper will freeze solid the instant the air temp gets down to 32. Those are the guys who put their campers up in October and don't use them again until May.
The air temp has to bring the water temp down to 32 before it will freeze, and that takes some time when the daytime temperatures have been warm. It has been in the 60's here, and later this week we're expecting a low of about 29. The temp will be below freezing for just a few hours, not nearly long enough to freeze the relatively warm water in the lines inside my camper.
We camped a couple of weeks ago and did not re-winterize, and we certainly aren't going to do it for a few hours of freezing temps following a daytime high of around 50 or 60.
Just take a close look at the weather forecast for the hourly temps in your area.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 03-24-2015, 01:49 PM   #9
We're leaving Fri (Mar 27) for 6 weeks with our first stop in Indianapolis. They are predicting freezing conditions there and it is still getting in the low teens here mid Mich... so this is what we did.
We did a complete de-winterization last weekend when it was in the 50's . This allowed us to check out the furnace, WH (Gas & Elec) pump and plumbing just to make sure everything was working after the winter. Then we decided re=winterize after we saw the low temp predicts.
We also set the thermoset to 40F because we already loaded the camper with some items that we thought might freeze. Since the all plumbing in in heated compartments, we probably could have left out the antifreeze step, but at $3/gal we did it anyway.
We will keep the antifreeze in until we reach the Indy GC where we will flush it out as we set up.
btw....This is the coldest "End of Mar" that I can recall in these parts
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 03-24-2015, 02:51 PM   #10
With the temps here in the Pocono's, you may want to wait till July to dewinterize.
cgotto1204 is offline   Reply With Quote
winter, winterize
