Old 12-30-2012, 06:17 PM   #11
New Member
burati1's Avatar
We us a Vornado on the low setting. Heats the trailer just fine. I'd rather use the free electricity at a camp ground than use propane. We are not full timers so we typically are not camped long enough to where we have to pay for electricity.
Coachmen Freedom Express 292BHDS
San Antonio, Texas by way of Nebraska
burati1 is offline   Reply With Quote
Old 12-30-2012, 06:29 PM   #12
LaydBack's Avatar
I agree. The way I see it $40 in heaters and a bit of my time will save lots of $$$ in propane. Also, my mod keeps the temp more even throughout the camper, while still circulating heat thru the basement, and you can also use the blower when using the AC. To me, it's a no brainer to get as much as you can for the fees....one fill up on my tanks pays for the 2 heaters.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
LaydBack is offline   Reply With Quote
Old 12-30-2012, 07:28 PM   #13
Graduate Member
RoadTrip's Avatar
Originally Posted by rlocicero View Post
Life is way too short to worry about a couple bucks worth of propane. Turn on your furnace and enjoy yourself. I can maintain 72 degrees using the furnace only but usually keep it at about 66 where I am comfortable. living in western New York we do get our share of cold camping weather. Let's put things in perspective. You pull a $30,000 trailer with a $45,000 truck. Is saving a few bucks on propane worth the trouble? Not as far as I am concerned.
I agree with you, and we're not really looking to find a cheap heat - although that is a VERY nice bonus. We mainly use our MH to see family. At least once per month. So Christmas was our first "winter" camp. The temp ranged from 19 to about 34 overnight.
For our furnace, that meant kicking on every 10 minutes. So sure, if we can get to 70 on two electric space heaters, bring it on!
But mainly I just want to have my furnace cycle less.
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 12-30-2012, 07:50 PM   #14
LaydBack's Avatar
I don't look at it as cheap.....I just know I have options....I can run the furnace normally with the electric heaters and have it cycle less, or maybe not at all. I can also keep the trailer comfy all day in case wifey or kiddos don't wanna be out in the cool/cold......to each his own....the mod is in the link in my sig.
LINK TO MY MODS
Old 12-30-2012, 08:25 PM   #15
caper's Avatar
We are on meters and have to pay for our hydro. Found that the electric haters maintained a more constant heat. Yes is was more economical to use hydro over propane. We were saving $50 to $75 per month. When on a fixed income it makes a difference.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 12-30-2012, 08:39 PM   #16
Have you thought about radiant electric floor heat like is used for residential installation? A more permanent solution, takes up no floor space, nothing to setup each trip, controlled by thermostat, etc. thermosoft is one brand but there are many others, often used in bathroom or kitchen renovations and easily DIY.
We only have a small A frame popup and use a micathermic radiant heater for the off-season camping, takes up little space and makes no noise whatsoever (no moving parts)
2011 A-122
rawlus is offline   Reply With Quote
Old 12-31-2012, 02:07 AM   #17
what about those infrared heaters? They have lower BTUs but claim larger heating square footage.
We have one for the house (stick) infra-red Eden Pure heaters . They work good but they are delicate to travel . The "bulbs" easily get destroyed with very little bumping . Wouldn't want to try transporting ours . Jim
FarmerJim is offline   Reply With Quote
Old 12-31-2012, 06:00 AM   #18
tncruiser's Avatar
i bet a lot of folks reading this wonder what "hydro" is
it is a term i dont hear very often but my mother still will sometimes call it hydro,my pepe' would say turn off them %&*M lights you tink we owed da hyro company. i have lived in the states ffor 66 years but i still remember ontario speak and i want to thank you for bringing to the front of my memory this morning
happy and healty new year
and safe travels in 2013
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 12-31-2012, 07:37 AM   #19
KyDan's Avatar
To a certain degree (no pun intended) amps can be converted to Watts and watts
to BTUs which are heat.
So if you get a 1400 watt heater, you are gonna get pretty much the same BTU over
various brands. Some have blowers, some don't. Some are oil filled, some are ceramic.
These have different effects. Oil filled don't use a blower and they tend to level out
the heat rather than off/on - warm/cold cycle of say one with a blower.
Oil filled are pretty much silent. Blowers make noise.
The bottom line is if 1400 watts won't keep up you need more watts.
One way to do that is with an extension cord stuck in thru the slide out gasket
which is plugged into the campground power post in the 120v duplex outlet.
This way you won't trip the outlet breaker in your trailer by plugging 2 heaters
in inside your RV.
If your question pertains to keeping your RV warm while parked at home the answer
is still more heaters using more watts and spending more $$ on your electric bill.
Electricity is cheaper than LP whether it's at home or in a campground.
My 2¢
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 12-31-2012, 10:20 AM   #20
VinceU's Avatar
Just keep in mind a 1500 watt heater is approx 1.5KW. The fixed heaters are from 15,000 to 35000 btu's. I just converted a 35k btu gas furnace to elec 1500 watt for comparison. It would take about 6.8 small elec heaters to match the output of the "big guys". I use both a firepllace at 1100 watts and a floor heater of 1500 watts. Sometimes ya just gotta kick in the big guy.
