Old 10-31-2013, 11:27 PM   #21
Denver, CO
garbonz's Avatar
Originally Posted by garbonz View Post
Better than me with a 2007 and 9200 lbs in tow. I am right at 10 from Denver to Bronson and back... Probable pull right at 65-68mph.
2007 duramax and Vcross 275VRL. Older Duramaxs must get lower MPH
2017 Fuse 23T
Old 11-02-2013, 09:22 AM   #22
Broke and happy
bobfa's Avatar
12.5
Had my new F250 SuperDuty 6.7L pull my 21' Micro-Lite (4000 lb.) from Houston to San Marcos. 65 MPH, gauge showed 12.5 mpg. It really did pull like there was nothing behind me.
Name:	2013-10-19 08.57.11.jpg
ID:	42190   Click image for larger version
Name:	2013-10-19 08.57.00.jpg
bobfa is offline   Reply With Quote
Old 11-03-2013, 11:02 PM   #23
Fuel mileage
Phoenix-Laughlin-Riverside, Ca-Phoenix towing a Vibe 6201 with 2006 Dodge 3500 Cummins. Ave 17.4 MPG. We had a 26 MPH head head wind from the Colorado River to near Phoenix.
John S is offline   Reply With Quote
Old 11-04-2013, 08:33 AM   #24
cogito ergo moo
Cowracer's Avatar
2002 Ford Excursion. DP Tuner 6-position chip, 4 inch exhaust, 8" lift, 37x13.30 MT Tires. Gets following milages:
EMPTY-
Chip position 1 (stock) - 12-13 mpg
chip position 3 (80 HP Econ) 14-15 mpg
chip position 6 (160 HP Race) 10-11 mpg
TOWING approx 8000# of Roo, gear and 4 wheelers-
Chip position 4 (40 hp Tow) 8-9 mpg
Chip Position 5 (60 hp Tow) 8-9 mpg
Chip position 3 (not recommended, but I use it anyway) 10-11 mpg
In case you are wondering, Position 2 is just stock with a 1750 rpm idle. I never drive in 2
Bear in mind that I tow at around 72 on the interstate. Ford diesels are happiest at about 1900 rpm, and thats 72 with my gears/tires. Unladen, I cruise at 80 or so most of the time.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 11-04-2013, 03:20 PM   #25
gmcnitt's Avatar
2009 Charleston 40' diesel pusher pulling a Jeep Wrangler toad at the speed limit (70-75) averaging around 7 mpg. I hear if I go slower I would get 10 or so......
gmcnitt is offline   Reply With Quote
Old 11-04-2013, 03:39 PM   #26
Brother Les's Avatar
Your trailer looks level, but your truck does not. Do you need to drop the ball an inch or so and then lift the truck and trailer up with the stabilizer bars?
Brother Les
Old 11-04-2013, 05:05 PM   #27
I tow my 27RLWS with a Chevy Avalanche 2500 with a 8.1 L and average 11 mpg.
2014 Flagstaff 27RLWS
2004 Chevy Avalanche 2500
1998 21' Thor (doesn't everyone need 2 TT's?)
eshenderson is offline   Reply With Quote
Old 11-04-2013, 11:20 PM   #28
Broke and happy
bobfa's Avatar
The dealer adjusted the hitch, and that was a pic first trip.Think the truck tilt is illusional mostly. A month later I see the trailer rear is tilted back a bit. Difference now the front storage area is loaded up full as well as storage areas to the front, and added a power jack. (went hog wild). Now seems to me the truck is about 1 inch to high with trailer tipped back alittle. Maybe will drop the hitch an inch and help level and distribute the weight better. Thanks I am NOOB. The trailer did look level ..... I have a E2 WDH sway control. I paid to have the hitch readjusted from my first TV which was a Pilot . I should have had a full load so will have to try and tweak it.
Old 11-04-2013, 11:57 PM   #29
I haven't checked the mileage on my new FR3 30 DS and I may not. Had to lie to get 9 mpg on my 03 Sightseer. I had a 99 Superduty 7.3L and a 9K trailer and got 13 to 15. Maybe I should just tow the coach. I've still got the truck.
Mandoholic and Bassbabe
2014 FR3 30DS
Salem, Oregon
Mandoholic is offline   Reply With Quote
Old 11-05-2013, 09:07 AM   #30
bradnailer's Avatar
I was getting around 7 the first few times I hauled my trailer, a Coachmen Freedom Express 233RBS being towed with a Jeep Grand Cherokee V8. I dropped the front of the trailer down a few inches and the last time I towed it I was at almost 9.
2016 Ford F150 Platinum
2013 Coachmen Freedom Express 233RBS
Prior: Jayco Pop Up, Shasta Bunkhouse, Rockwood 2560G Pop Up
bradnailer is offline   Reply With Quote
mpg
