Old 09-27-2015, 11:55 AM   #11
milvet33's Avatar
Texas Heat
When was the last time VA had 45 straight days of 100+ temps with night temps in the high 80"s? The number of days does matter.
milvet33 is offline   Reply With Quote
Old 09-27-2015, 02:32 PM   #12
Dabmeb's Avatar
We have traveled all over Canada and the US in a semi and never had water actually running down the windows on the inside until we started going to Laredo. We have had to use a hair drier to melt the ice buildup on the air intake side of the AC. Only had that happen once on the east coast and it was during a rain storm.
Dabmeb is offline   Reply With Quote
Old 09-27-2015, 03:48 PM   #13
7 Year Class A RV'er
It's not just humidity that will impact you. In fact, with AC running, I personally don't feel humidity impacts you at all. Having grown up in Texas and living in Florida for the last 17 years, I can tell you that there are other things that make it much harder to cool in Texas or Florida than Virginia, for example. In Florida, the UV is beyond belief. If you can get in the shade, most days in Florida are actually quite pleasant. Nights, too, as the evening breeze picks up and the sun is gone. In Texas, you not only gave to deal with sun and no shade, you have an almost constant wind that's like an open oven door. Also, it can still be in the 90's well after 10 PM each night. Before factory AC was standard in cars, we had to be sure we always left a window cracked in summer or it could actually blow a windshield right out of the car. Yes, it can be hot in VA, but I will tell it's not like Texas.
2015 Legacy SR340 360RB
Old 09-27-2015, 07:20 PM   #14
A simple math answer - there are greater and lesser degrees of 100.
Middleburg Redneck is offline   Reply With Quote
Old 09-27-2015, 07:47 PM   #15
Bluepill's Avatar
In my experience, areas like Texas, NM, and AZ have light-colored ground which reflects extra sunlight onto the side of the RV In effect you can get a double dose of BTUs. As mentioned above, the higher temps at night do not allow the heat that has built up during the day to dissipate, so the whole RV gets heat soaked.
2008 Itasca Meridian 37H
Old 09-27-2015, 08:31 PM   #16
Well, mide as well have two ranges, two hot water heaters, two tow vehicles, two water pumps, two toilets, ........... Geeze.
Handydc is offline   Reply With Quote
Old 09-27-2015, 08:43 PM   #17
gashog's Avatar
Originally Posted by nomad297 View Post
Just to be clear that I'm not criticizing those who do have two air conditioners, I wish I had two, but I have never looked at a trailer I liked that had two, and I am too impatient to order a custom trailer. The reason I would like two units, though, is not for the cooling efficiency, rather, for the peace of mind of having a spare in case one of them quit working.
Bruce
Interesting, I thought (2) AC's were part of the Diamond Package. What service does yours have 30 or 50 amp? I bought my off the dealers lot (2) AC's and 50 amp..just figured that how they all were.
2015 Rockwood Windjammer 3029W Diamond Package
2014 RAM 2500 Laramie Longhorn 4 x 4
6.4 Hemi 410 HP, 410 Rear Axle
gashog is offline   Reply With Quote
Old 09-28-2015, 12:53 PM   #18
In the northern part of the country, while it does get hot during the day it at least cools down in the evening. In florida if it's 91 degrees during the day, it might cool down to 84 at night. Not much of a difference. Also with the humidity being terrible 24/7, that doesn't help either. Most of the trailers sold down here have 15kbtu rather than the 13.5 kbtu's, and believe me it helps
2015 274 RK LIMITED <'{{{{><
captainperry is offline   Reply With Quote
Old 09-28-2015, 01:03 PM   #19
jeff64's Avatar
Originally Posted by fonzie View Post
x2 and correctly so. Add in the absorbed radiant energy in all these new darker brown ( instead of white) RVs. I bought mine with the 13.5K instead of the 15K and wish I'd have considered that more carefully.
I have been evaluating a electronic( peltier) dehumidifier understanding the latent heat of vaporization concept. We're getting a little late in the season for high heat and humidity in this area. But, we are running the heat and what I notice is that this past weekend I can pull about 16 oz/ day out of the air and I don't see the condensation on the windows in the am.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 09-28-2015, 01:11 PM   #20
Boss Ox & Drovergirl
oxcamper's Avatar
Isn't 100 degrees there the same as 100 degrees here...and everywhere? What am I missing?
Bruce
BECAUSE... Everything is bigger in Texas
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
