Old 03-26-2016, 11:33 PM   #11
Seriously? A thread about checking tire pressure? How about at the same time as your Towing rig? Small compressor, every truck stop you stop to fill up?
Kuba is offline   Reply With Quote
Old 03-27-2016, 10:59 AM   #12
I carry a air compressor and two Honda's to air up any time but mostly in the morning before heading out.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 03-28-2016, 06:19 PM   #13
Vladivar's Avatar
Can anyone educate me on how this relates to Nitrogen filled tires? Is the pressure checking still a regular requirement - and where would you get them topped up?
Vladivar is offline   Reply With Quote
Old 03-28-2016, 06:53 PM   #14
Ford Idaho's Avatar
Google had this information.
By volume, dry air contains 78.09% nitrogen,20.95% oxygen, 0.93% argon, 0.039% carbon dioxide, and small amounts of other gases. Air also contains a variable amount of water vapor, on average around 1% at sea level, and 0.4% over the entire atmosphere.
I have no idea how many RV dealers have it and I do not recall any tire stores that had it.
Old 03-28-2016, 07:01 PM   #15
I've got 2 travel trailers with nitrogen tires (8 total tires) and my tow vehicle has nitrogen filled tires.
I put air in there when they're low. I think the nitrogen is kind of a gimmick.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 03-28-2016, 10:03 PM   #16
nitrogen is used because it changes the tire pressure much less than air does when the temp rises,....that may or may not be a benefit that you consider worth paying for,......finding nitrogen to top off or refill a tire can be difficult, and there is always a cost, it isn't free from any shop that I know of, usually $10/tire,..........mixing air into a nitrogen filled tire causes no problem at all, you just begin to lose that benefit for which the nitrogen was used in the first place, ......is it worth the trouble of hunting down a shop that has nitrogen and then paying for it?.......not to me.................
fella10 is offline   Reply With Quote
Old 03-28-2016, 11:44 PM   #17
A myth: https://powertank.com/truth.or.hype/
Skyliner is offline   Reply With Quote
Old 03-29-2016, 05:19 AM   #18
Originally Posted by TonyD View Post
I was giving the industry's explanation for using nitrogen, I've been told that by more than one trusted mechanic and a Google search will repeatedly show the same answer,.....I wasn't endorsing the use of nitrogen,....... but this "myth buster" you trust sells a system that competes with nitrogen, that's like Pepsi listing 9 "facts" of why Coke is awful, but Pepsi is amazing!!! .....to each his own......
Old 03-29-2016, 06:04 AM   #19
USN Desert Storm Vet
Send a message via Skype™ to bfhammer
Costco combo jump pack and compressor. It works great for both and it can be used for pool toys, balloons, additionally.
bfhammer is offline   Reply With Quote
Old 03-29-2016, 07:21 AM   #20
Thinking that I wanted to be prepared for anything, I bought the Stanley Fatmax, which includes a compressor, light, inverter, usb charger, jump starter, and probably a corkscrew. Using it to top off 75 and 80 psi tires, it began to smoke and then stopped from overheating. Once cool, per the manual, tried again and it wouldnt even budge the psi a lb. Got my $ back and bought a real compressor, fills easily, but miss the corkscrew. ;-)
Linda
LTRVing is offline   Reply With Quote
tire, tires
