Old 08-20-2012, 06:41 PM   #1
Where can I get this valve
It is a 2006 Thor Summit 22RB. I am guessing it was installed as an aftermarket piece? Any reason why somebody would installed this? It does have an outside shower in the rear.
The cold water valve leaks when I turn the city water line on. Just slow drip, but I like to replace. Note: above is the tub in the restroom.
It looks like a clamp is holding the valve/hose together.
tntrac is offline   Reply With Quote
Old 08-20-2012, 06:54 PM   #2
hotrodj125's Avatar
Menards, Lowes, Home Depot in the plumbing Dept uner PEX fittings you should be able to find a valve to replace it. You will have to put on a new clamp also, but a side cutter will sinch taht together.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 08-20-2012, 06:58 PM   #3
Thank you. Do you think this was an aftermarket installed? I am sure you know this, but I forget to state these valves are plastic like.
Old 08-20-2012, 07:03 PM   #4
Blackrock's Avatar
Those are the low point water drains and were factory installed.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
Old 08-20-2012, 07:04 PM   #5
I see. The holes were cut nicely so it had to be from factory
Old 08-21-2012, 07:11 AM   #6
That would be 1/2 inch pex tubing, and that is not a clamp but a crimp ring. No clamp will hold it. You need a new crimp ring, and a special tool to crimp.The valve will also need a male barb on one end, to go in the pipe. Lowe's / Home Depot will rent you a tool.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-21-2012, 08:39 PM   #7
hotrodj125's Avatar
Whoops, ya thats right - crimp ring-- Had a senior moment-- but i have used a large wire cutter to pull the crimp ring together, but i did go buy the tool, these fittings and crimp rings come in handy in a lot of uses..
and yes, Lowes or Home Depot will rent you the tool.
Rod & Linda Johnson
Cedar, Minnesota
2012 Columbus 320RS
K-9's Lucy & Lizzie
Old 08-21-2012, 09:15 PM   #8
I would say if the holes were cut(Nicely) that they were (NOT) done at the factory. Just joking they are fac. low point drains. Youroo!!
Old 08-22-2012, 11:55 AM   #9
I assumed this is the drain from the fresh water line?
Old 08-22-2012, 12:42 PM   #10
Cmmjmoore's Avatar
Did you say new tool ! I don't need to work on my water lines, but damn a new tool. Thanks Windrider I am on my way to the hardware department.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
Old 08-22-2012, 09:20 PM   #11
Dam. I am trying to avoid the new tool purchase!
I went to Home depot and saw a copper valve that you can slip the pipe in (no crimp tools, etc). I was curious and tried it myself and couldn't pull it out .
So for the PEX, I can just use my pvc cutter? I am thinking of just cutting a piece away and buy the slip on valve. The copper was a little heavy for my taste though for something hanging
Old 08-22-2012, 09:31 PM   #12
TURBS's Avatar
Shark bite fitting ?
Old 08-22-2012, 09:37 PM   #13
Yep. Didn't buy it though since the copper was kind of heavy.
Old 08-22-2012, 09:40 PM   #14
TURBS's Avatar
The make poly ones to.
Www.Grainger.com
Plumbing section .
I grabbed several different fittings at my local graInger store for (emergencies)
Old 08-22-2012, 09:48 PM   #15
Www.Grainger.com
Plumbing section .
Would this work for a 1/2" pipe (see original post)
http://www.grainger.com/Grainger/ZUR...617?Pid=search
Old 08-22-2012, 10:11 PM   #16
You can buy valves and fittings that do not require the crimp ring. They will work on pex tubing and have a compression type nut that will hold them on. They also have a insert barb made on them that goes inside the pex tubing. You can cut the tubing with a hacksaw, just make a straight cut.
I used the 3 way valves to make a bypass around the onboard water filter, now I can bypass it and winterize. Just have to empty the water out of the filter.
I purchased the valves on line from Dyers RV. You local RV store may have some in stock.
wvcampers is offline   Reply With Quote
Old 08-23-2012, 10:57 AM   #17
I notice the barb fitting too. For the barb, do you need the crimp ring?
The guy at Home Depot barely knew his stuff.
Old 08-23-2012, 12:06 PM   #18
I'm sorry, but how hard is this? My low water drains had caps, and I got tired of finding tools. One trip to Home Depot, two plastic valves, a pack of crimp rings, and two hour tool rental, less than $25, even counting gas for both trips. Sorry, but I hate to see people spend so much time and effort trying to patch something when it is cheaper, and quicker to do it right. Shark Bite fittings work, but they are high, and don't like the vibration. I keep a couple in case something breaks while camping, not to install on a camper and leave. Just my two cents, do it right, and be done. PM an address if you like and I will send you my old fittings with caps. You will still need the crimp rings and tool though.
LadyWindrider
Old 08-23-2012, 12:19 PM   #19
TURBS's Avatar
Only if your going to crimp it.
Get the one that just slides over the pex and holds tight.
Old 08-23-2012, 02:10 PM   #20
You do NOT need the crimp ring or the special tool to use the valves with the barb and nut. They do not come in colors they are white only. Just cut your old valve off, slide the new nut on the outside of the tubing, then the valve barb will insert into the tubing, tighten the nut and you are done.
