Old 08-20-2012, 06:41 PM   #1
Where can I get this valve
It is a 2006 Thor Summit 22RB. I am guessing it was installed as an aftermarket piece? Any reason why somebody would installed this? It does have an outside shower in the rear.
The cold water valve leaks when I turn the city water line on. Just slow drip, but I like to replace. Note: above is the tub in the restroom.
It looks like a clamp is holding the valve/hose together.
tntrac is offline   Reply With Quote
Old 08-20-2012, 06:54 PM   #2
hotrodj125's Avatar
Menards, Lowes, Home Depot in the plumbing Dept uner PEX fittings you should be able to find a valve to replace it. You will have to put on a new clamp also, but a side cutter will sinch taht together.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 08-20-2012, 06:58 PM   #3
Thank you. Do you think this was an aftermarket installed? I am sure you know this, but I forget to state these valves are plastic like.
Old 08-20-2012, 07:03 PM   #4
Blackrock's Avatar
Those are the low point water drains and were factory installed.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 08-20-2012, 07:04 PM   #5
I see. The holes were cut nicely so it had to be from factory
Old 08-21-2012, 07:11 AM   #6
That would be 1/2 inch pex tubing, and that is not a clamp but a crimp ring. No clamp will hold it. You need a new crimp ring, and a special tool to crimp.The valve will also need a male barb on one end, to go in the pipe. Lowe's / Home Depot will rent you a tool.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 08-21-2012, 08:39 PM   #7
hotrodj125's Avatar
Whoops, ya thats right - crimp ring-- Had a senior moment-- but i have used a large wire cutter to pull the crimp ring together, but i did go buy the tool, these fittings and crimp rings come in handy in a lot of uses..
and yes, Lowes or Home Depot will rent you the tool.
Rod & Linda Johnson
Cedar, Minnesota
2012 Columbus 320RS
K-9's Lucy & Lizzie
Old 08-21-2012, 09:15 PM   #8
I would say if the holes were cut(Nicely) that they were (NOT) done at the factory. Just joking they are fac. low point drains. Youroo!!
Old 08-22-2012, 11:55 AM   #9
I assumed this is the drain from the fresh water line?
Old 08-22-2012, 12:42 PM   #10
Cmmjmoore's Avatar
Did you say new tool ! I don't need to work on my water lines, but damn a new tool. Thanks Windrider I am on my way to the hardware department.
2013 SP 240 Anniversary
Tundra CrewMax 5.7L in Pyrite Mica
Clark, Mary Jane & Max our German Short-haired Pointer
(2011-42)
Cmmjmoore is offline   Reply With Quote
