Old 06-03-2016, 08:52 PM   #21
I think I will throw $13 at one of these, and see how it goes!
RV LED 12V Fixture Ceiling camper Trailer Marine Double Dome Light F3528002 1 | eBay
2010 Surveyor Sport 189
2004 Palomino Bronco
KansasBob is offline   Reply With Quote
Old 06-03-2016, 09:09 PM   #22
These are what I purchased and I am very satisfied with them.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 06-03-2016, 09:21 PM   #23
Bluepill's Avatar
K-Bob
Good info. Making the same list was on my to-do list.
One less thing to do.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 06-03-2016, 09:28 PM   #24
Originally Posted by stevejahr View Post
Sounds very much like mine: circuit board in LED light/switch housing. One cable is 4 pins to provide power/ground/switch/LAC connections. Other cable is 2 pins for heat strip. No need to cut wires when you can just unplug.
I think you have a different model fridge than "most" of us have. You're only the 2nd person I know of that's mentioned a different heat strip connection. What model do you have?
2011 Traverse LT, 3.6L, FWD
Old 06-04-2016, 09:39 AM   #25
Originally Posted by Bluepill View Post
K-Bob
I thought I recognized the Avatar from ADV. If you are ever on Face Book drop by my group. Vintage Enduro Buyers and Sellers Guide.
Old 06-04-2016, 09:57 AM   #26
Interesting...... how do you urrr..... "affix" the led panel to the light?
Old 06-04-2016, 10:10 AM   #27
They have double sided tape on the back of the board which sticks to the flat surface on the inside of the fixture really well. Have had these installed for two years now without a problem.
2007 Surveyor SV230
Old 06-05-2016, 03:51 PM   #28
Took some more readings today.
Digital auto search signal Booster, TV attached................0.25 amps
21" SkyWorth 12 volt TV..............................................1. 65 amps
12 volt computer speakers plugged in headphone jack.......0.1 amps
(Much Better Sound)
Judging by the rating on the Optmia deep cycle battery label, I should be able to run the TV, and speakers for 24 hours without knocking it completely flat. I think the SkyWorth is rated to operate as low as 11 volts...... maybe a little lower.
Old 06-07-2016, 01:42 PM   #29
Learning a lot as I go...
DMR702 -- 2015 production date with blue interior LED lights.
stevejahr is offline   Reply With Quote
Old 06-07-2016, 03:39 PM   #30
Owners manual for the series 7 shows the door heater in parallel with the interior light and light switch, so it seems that the "fix" should be the same, unless the place where the two circuits tie together is not inside the interior light like it is in the DM2652-style fridges.
See pg 23:
http://www.dometic.com/QBankFiles3/E...-Web_29111.pdf
power
