06-03-2016, 08:52 PM
#21
2010 Surveyor Sport 189
2004 Palomino Bronco
06-03-2016, 09:09 PM
#22
Originally Posted by KansasBob
These are what I purchased and I am very satisfied with them.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
06-03-2016, 09:21 PM
#23
K-Bob
Good info. Making the same list was on my to-do list.
One less thing to do.
06-03-2016, 09:28 PM
#24
Originally Posted by stevejahr
Sounds very much like mine: circuit board in LED light/switch housing. One cable is 4 pins to provide power/ground/switch/LAC connections. Other cable is 2 pins for heat strip. No need to cut wires when you can just unplug.
I think you have a different model fridge than "most" of us have. You're only the 2nd person I know of that's mentioned a different heat strip connection. What model do you have?
2011 Traverse LT, 3.6L, FWD
06-04-2016, 09:39 AM
#25
Originally Posted by Bluepill
K-Bob
I thought I recognized the Avatar from ADV. If you are ever on Face Book drop by my group. Vintage Enduro Buyers and Sellers Guide.
06-04-2016, 09:57 AM
#26
Interesting...... how do you urrr..... "affix" the led panel to the light?
06-04-2016, 10:10 AM
#27
They have double sided tape on the back of the board which sticks to the flat surface on the inside of the fixture really well. Have had these installed for two years now without a problem.
06-05-2016, 03:51 PM
#28
Took some more readings today.
Digital auto search signal Booster, TV attached................0.25 amps
21" SkyWorth 12 volt TV..............................................1. 65 amps
12 volt computer speakers plugged in headphone jack.......0.1 amps
(Much Better Sound)
Judging by the rating on the Optmia deep cycle battery label, I should be able to run the TV, and speakers for 24 hours without knocking it completely flat. I think the SkyWorth is rated to operate as low as 11 volts...... maybe a little lower.
06-07-2016, 01:42 PM
#29
Learning a lot as I go...
DMR702 -- 2015 production date with blue interior LED lights.
06-07-2016, 03:39 PM
#30
Owners manual for the series 7 shows the door heater in parallel with the interior light and light switch, so it seems that the "fix" should be the same, unless the place where the two circuits tie together is not inside the interior light like it is in the DM2652-style fridges.
See pg 23:
http://www.dometic.com/QBankFiles3/E...-Web_29111.pdf
06-07-2016, 08:30 PM
#31
See pg 23:
Oh they are in parallel. My point is that the way it is put together you can just unplug the strip heater from the light circuit board. No wires cut, everything completely reversible if needed, and your fridge lights will still work. I am going to put together some pictures when I get it all modified
06-07-2016, 08:57 PM
#32
OK. Didn't understand what you meant. I'm sure pics would be helpful for DMR702 owners.
