Old 08-19-2014, 04:18 PM   #1
Where is the Fresh H2O tank drain plug
I have a 2013 Surveyor SP220 Trailer.
I need to find the drain plug for the fresh water tank.
Is it located behind the front tire on right side. This hose has a screw off cap with some kind of rubber plug inserted in the opening. This plug has a square 1/4" hole in it that doesn't go all the way through the plug. Also above this hose is where the fresh water inlet is located too.
Thanks for any help I get.
Dibbie is offline   Reply With Quote
Old 08-19-2014, 04:53 PM   #2
My 2012 SP220's is located on the curb/door side just behind the rear wheel. Model years do change, but if by "right side" you mean the door side then that is probably correct. Screw off cap with hose threads and an internal rubber plug. The plug itself is threaded. It sounds like the fresh water inlet is in the same place... just in front of the curb side wheel. I think you got it. That would be the low point drain. Hope that helps.
rana is offline   Reply With Quote
Old 08-19-2014, 06:14 PM   #3
Found it right where to told me. Thanks.
drain, tank
