Old 03-21-2018, 09:28 AM   #21
Wolverine 1945's Avatar
Originally Posted by cavie View Post
Some valves will be outside and visible. Some will be inside and hidden.
Let me see. Open valve inside. Go outside and see if it's draining. Go back inside when it stops to turn off to keep critters out of the pipe. Repete for other valves. Yeper, that's some fine engineering. My valves are on the outside of my 5er. Your location may be different. overflow drain will be white. low point drains will be blue and red.
I think I have a Blue one with cap,,, and a clear with no cap !!!
They are right under the storage compartment where the fresh water drain valve is !!!
Wolverine 1945 is offline   Reply With Quote
Old 03-21-2018, 09:32 AM   #22
Water lines are red and blue throughout the unit. Drains are clear or white. My brain tells me the fresh water drain valve would have to be UNDER the tank to drain right?
Old 03-21-2018, 09:57 AM   #23
Right On !!!
Old 03-21-2018, 02:33 PM   #24
Loving this thread! sub'd
terryna is offline   Reply With Quote
window
