Originally Posted by cavie
Some valves will be outside and visible. Some will be inside and hidden.
Let me see. Open valve inside. Go outside and see if it's draining. Go back inside when it stops to turn off to keep critters out of the pipe. Repete for other valves. Yeper, that's some fine engineering. My valves are on the outside of my 5er. Your location may be different. overflow drain will be white. low point drains will be blue and red.
I think I have a Blue one with cap,,, and a clear with no cap !!!
They are right under the storage compartment where the fresh water drain valve is !!!
