Old 08-12-2016, 09:49 AM   #1
jstaffon's Avatar
Why does my rig jiggle?
I have a Rockwood 8299BS 5th wheel. It has the heavy duty jacks (yellow support braces) in the rear of the trailer. After leveling my trailer and setting the rear jacks, my camper jiggles and moves when walking around inside. I'm not sure what else to do to keep the camper steady. I have a tri-pod to attach to the hitch but I can't imagine it will make that much difference in side-to-side movement. Any tips or tricks?
2013 GMC Sierra 2500 HD, Duramax
2016 Forest River Rockwood 8299BS
jstaffon is offline   Reply With Quote
Old 08-12-2016, 10:03 AM   #2
AquaMan's Avatar
Jt Strongarms or something similar. Diagonal bracing is about the only way to reduce movement. If you're on a seasonal site, you can add some screw jacks under the frame in front and behind the tires.
2016 Georgetown 364TS
Nights Camped 2017 - 16
Old 08-12-2016, 10:27 AM   #3
jstaffon's Avatar
I've seen the JT Strongarms before. Are they something I can install myself or do you recommend having a service shop do the installation? I'm somewhat handy with tools.
Old 08-12-2016, 10:36 AM   #4
they are not bad to install. you can do it yourself in a few hours at most. mine definitely helped the movement inside..
rob
rcrupper is offline   Reply With Quote
Old 08-12-2016, 10:44 AM   #5
We may well go that route, but we are going to try the Valterra RV stabilizers first.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 08-12-2016, 11:22 AM   #6
NMWildcat's Avatar
There are tons of devices out there for RV stabilization. Most work to a degree, some are just gimmicks. Probably best bang for your buck in the long run are SteadyFast or strongarms. Or you can go the cheaper route of the same principal with the ratchet strap frame stabilizers. They are just a pain to setup depending how often you move.
Just know that no amount of devices will eliminate 100% of the movement. Hope all your 'jiggles' are small ones
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 08-12-2016, 11:29 AM   #7
TURBS's Avatar
Jt strong arms !
Loose the tripod, bulky, heavy, and hard to store.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "25"
Old 08-12-2016, 11:53 AM   #8
jstaffon,
As I've pointed out to you before, we have the sister Flagstaff 8529IKBS.
There are several trains of thought to help with this and most have been mentioned.
1.
A. X-Chocks between the wheels & tires.
Get the narrow, not the extended version and you'll still need to crank them tight together to get them between the tires. Then, once inserted, tighten between the tires to stop the 'rolling' movement
B. When leveling, leave the front just ever so slightly low and then run down your rear stabs. Once they are down, raise the front end back to level with the front jacks.
This will allow you to put just slightly more pressure on the rear stab than what you are able to do normally.
C. Obtain two scissor type jacks and use under the axles on each side to reduce the bounce in the center. Because of the design of the torsion axle suspension and the lengthy distance from the front to rear stabs, you really need something there for support. Harbor Freight has them very reasonable.
2.
JT's Strong Arms or SteadyFast systems.
Either of the methods above will remove about 90 some percent of your jiggle.
Then there is # 3.
Combination of both.
Rock Solid!
It just depends how susceptible you are to movement and how much you want to do during set-up.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 08-12-2016, 11:55 AM   #9
Let us know how they work out. I'm interested
larryo is offline   Reply With Quote
Old 08-12-2016, 11:58 AM   #10
B and B's Avatar
X345
