Old 04-08-2016, 06:46 AM   #1
WiFi
Has anyone used a WiFi booster in there RV to pickup signal to use Amazon Fire streaming system?
Marty f g is offline   Reply With Quote
Old 04-08-2016, 06:54 AM   #2
Kenny kustom's Avatar
Careful. There's some toes that might get steeped on.
A) wifi will be way too slow to stream.
B) that would be kind of rude, to hog all the bandwidth even if it did work.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-08-2016, 06:57 AM   #3
Left Coast
X2
Old 04-08-2016, 06:58 AM   #4
2016 Sabre 36QBOK
I just had a wifi booster tube and repeater delivered from TechnoRV. Will let you know how it works after next week.
Marty
2016 Rockwood 2703WS Sapphire
2011 Ford F150 EB
Martsing is offline   Reply With Quote
Old 04-08-2016, 07:55 AM   #5
WestCoastRV'er's Avatar
Last weekend I was streaming Amazon Prime, Netflix on my FireTV on the CG wifi. Technically it can be done but relies on CG bandwidth which we all know is ok at best.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 04-08-2016, 07:58 AM   #6
Some CG will kill the wifi when they see someone eating up a lot of bw. If you have Amazon Prime you can download movies and keep them for 48 hours I believe. We do that for trips when rain is in the forecast.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=2
Electra glide is offline   Reply With Quote
Old 04-08-2016, 08:18 AM   #7
Left Coast
WiFi is for everyone... What about other people?
Old 04-08-2016, 08:18 AM   #8
During prime season I'm sure using CG wifi would be useless. There is xfinity wifi available where I normally go. Once I can figure out how to get connected via my wifi booster I will set.
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 04-08-2016, 09:06 AM   #9
CWSWine's Avatar
I use one if I can't get a reliable connect. These don't steal bandwidth from others or allows you to hog bandwidth but enables you to hold a connection. If I have good connect that doesn't drop I don't use it nor do I use it to stream video. This one sets up a laptop like it is a hot spot then you connect your devices though the laptop.
http://www.amazon.com/Crane-Super-US.../dp/B004UR72IM
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-08-2016, 09:27 AM   #10
Left Coast
I just use a hot spot...WiFi in Quartzsite was not reliable
