Old 07-18-2016, 03:37 PM   #11
WolfWhistle's Avatar
Originally Posted by northstar1960 View Post
you can also ass the reflectix out side the slide walls , being as mine are black they really absorbed the heat . after covering with the reflectix it cut the AC use in half . where it could not keep up set at 70 to turning on and off like one would expect . Also did the windows
Hey Lou, I am thinking about painting the slide side walls a light gray like the gelcoat. You are right... they get darn hot.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
A Modder's work is never done!
Old 07-18-2016, 04:12 PM   #12
Hey ck out the mod by Herk he took the cover off his Ac an insulated the air box, I did this mod my self an it has helped,
Soga65 is offline   Reply With Quote
Old 07-18-2016, 04:14 PM   #13
northstar1960's Avatar
WW . They get to hot . don't know why they would use black . it may look nice but not very good in hot weather . mine sported the the reflective coating all winter . sounds funny but you know Fl winters
northstar1960 is offline   Reply With Quote
Old 07-18-2016, 08:17 PM   #14
Excellent idea... my nice looking black Dometic AC cover is going to end up white soon. I'm not an expert, but white has to be more efficient than black. I am also considering getting more vent insulators thingies and making cover for the sky light over the shower, for when it is hot like it is now.
WW
XLR Hyperlite 29HFS
Ram 2500 6.7L CTD
Triumph Thunderbird
Old 07-19-2016, 11:07 AM   #15
RiverPeeps's Avatar
Will a second AC help?
Im gonna add a second ac to our bedroom also
07 Silverado Classic 2500 HD
15 Flagstaff 26fkws Emerald Edition
RiverPeeps is offline   Reply With Quote
Old 07-20-2016, 08:25 AM   #16
I have a 2608ws with one 15k AC. We're out here now in New Mexico and we barely keep cool during the day. We turn off all lights, use the tin foil covers in the Windows, minimize cooking, and just keep still. Yes another AC would be helpful. Our next unit will have two. putting a grand into it would be good if you're going to keep it.
Robb
robbdrell is offline   Reply With Quote
Old 07-20-2016, 08:44 AM   #17
Second AC
Go for it! We added a second 15,000 after staying in 100 degree heat last year. Only been in 90 degree heat so far this year. Just to see if it would I set both zones a 68 degrees. Maintained that temp with no problem.
C.B.
cbvp is offline   Reply With Quote
Old 07-20-2016, 08:51 AM   #18
Phat Phrog Stunt Crew
elind's Avatar
I added a second A/C in the bedroom and it made the difference. Would it help when parking your RV to pick a site that the awning faces south. It would help burn off the direct sunlight on the dark sides.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is offline   Reply With Quote
Old 07-20-2016, 11:05 AM   #19
RiverPeeps's Avatar
I just ordered this
Comes complete with ceiling grill
https://www.ebay.com/itm/262457773964
Old 07-20-2016, 02:30 PM   #20
I've often wondered why RV air conditioners suck. Is it merely a tonnage issue, or is there more to the story?
325BH is offline   Reply With Quote
