07-17-2016, 04:07 PM
Will a second AC help?
We have a new Rockwood 2905ws that we bought in May. It currently has a 15000 AC, but we are thinking about adding a 2nd AC in the front bedroom.
My question... is it worth $1000? Our AC will cool about 20 degrees lower than the outside temperature and that's what I understand to be on par. In texas this weekend it was 100 outside and the camper was 80 inside during the day and around 68 during the night.
Would adding a 2nd AC make the camper cooler during the day or would a 20 degree difference still remain? Would 2 ACs keep the camper say 70 or so during a 100 degree day?
Sent from my SM-T810 using Tapatalk
07-17-2016, 04:26 PM
More cooling capacity will help. May not achieve the 70 but get you another 10 degrees. There are some thread on here with people adding a second AC and running this on a separate 20 amp circuit.
I have thought about doing the same thing.
B and B
07-17-2016, 04:36 PM
Thinking of doing this to my 2013 831ress , But putting the second Ac in the vent above the main living area really don't need it in the bed room as it it gets plenty cool at night , also thinking of going with a power saving Ac so I can run it of my generator when I boondock , probly just run a separate power an plug straight into the pedestal at the campground
07-17-2016, 04:39 PM
I believe the main problem with temp control in modern TTs and 5th wheels is a lack of proper insulation. It's like living inside an oil drum in full sunlight. Not much you can do about it unless you can install or pump more into the walls and ceiling. I'm sure a second AC would help, just don't know how much and that is only if you are wired for 50 amps, because you WILL need it to run two units.
We had a Keystone Passport before our Aviator and it had only one AC unit and it struggled to keep it livable inside. Our Aviator has as much as 5" of slab styrofoam in the walls and ceiling and we only use one AC [15,000 btu] even at 100* outside. It still cycles on and off when set at 72*. We haven't used the bedroom AC in over two years.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
07-17-2016, 04:49 PM
Georgia Rally Coordinator
Defiantly add the 2nd air will make a big difference. I have two on mine and in 96 degree heat i can cool to 72 degrees and if some shade even better. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-18-2016, 09:03 AM
Thanks for the feedback. Im just over thinking it I guess. Will need to pull the trigger and just do it I guess.
07-18-2016, 09:12 AM
You could try putting reflectix insulation cut to fit the windows in the bunk/bedroom areas too. I did this before our trip to Branson, where the weather was 96+ all week and our 13,500BTU unit kept up with it all week and kept temps in the low 70's. It even turned off a few times. Before in temperatures similar, it was constantly running and not keeping up. It only costed me $10 for the roll....plus it keeps the sleeping areas nice and dark!
2016 Grey Wolf 26DBH following a 2014 RAM 1500 Outdoorsman
Life is good...Live it!
Nights Camped - (2014) - 16 in 6 trips (2015) - 20 in 6 trips
(2016) - 21 in 7 trips
(2017) - 12 in 3 and going seasonal for at least the rest of the year!
07-18-2016, 02:24 PM
I also live on the Texas Gulf Coast and my 38 foot fiver has two ACs, 15000 ducked in the living area and 13,500 ducked in the bedroom. They do an excellent job even in the Texas summer.
I didn't like the non-ducked 13,500 that I had in the bedroom of my last fiver. It is off or on and it did make lots of noise. Good Luck
07-18-2016, 03:20 PM
At 100 degrees, my single ducted 13.5 will probably only make 80 / 81 degrees. So, I added a Haier 10K BTU portable in the garage (toy hauler) on its own 20A feed for hot weather camping. With it both running I can easily get to my goal, which is about 76 - 77 degrees. The Haier sits on the floor and is ducted through the floor, the nice things is how quiet it is and that in a pinch I can run it off of my Honda 2000EU and sleep in the bed back there. I also love that it has dehumidifier and fan only modes, as well as having a remote control. When I'm home, I put in the bedroom and save on my electric bill. I sound like a Haier commercial, I know.
I have reflectix for all windows and have added insulation to the entire floor.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
07-18-2016, 03:35 PM
you can also ass the reflectix out side the slide walls , being as mine are black they really absorbed the heat . after covering with the reflectix it cut the AC use in half . where it could not keep up set at 70 to turning on and off like one would expect . Also did the windows
07-18-2016, 03:37 PM
Hey Lou, I am thinking about painting the slide side walls a light gray like the gelcoat. You are right... they get darn hot.
WW
Hyper Lite was sold
07-18-2016, 04:12 PM
Hey ck out the mod by Herk he took the cover off his Ac an insulated the air box, I did this mod my self an it has helped,
07-18-2016, 04:14 PM
WW . They get to hot . don't know why they would use black . it may look nice but not very good in hot weather . mine sported the the reflective coating all winter . sounds funny but you know Fl winters
07-18-2016, 08:17 PM
Excellent idea... my nice looking black Dometic AC cover is going to end up white soon. I'm not an expert, but white has to be more efficient than black. I am also considering getting more vent insulators thingies and making cover for the sky light over the shower, for when it is hot like it is now.
WW
Hyper Lite was sold
07-19-2016, 11:07 AM
Im gonna add a second ac to our bedroom also
07 Silverado Classic 2500 HD
15 Flagstaff 26fkws Emerald Edition
07-20-2016, 08:25 AM
I have a 2608ws with one 15k AC. We're out here now in New Mexico and we barely keep cool during the day. We turn off all lights, use the tin foil covers in the Windows, minimize cooking, and just keep still. Yes another AC would be helpful. Our next unit will have two. putting a grand into it would be good if you're going to keep it.
Robb
07-20-2016, 08:44 AM
Second AC
Go for it! We added a second 15,000 after staying in 100 degree heat last year. Only been in 90 degree heat so far this year. Just to see if it would I set both zones a 68 degrees. Maintained that temp with no problem.
C.B.
07-20-2016, 08:51 AM
Phat Phrog Stunt Crew
I added a second A/C in the bedroom and it made the difference. Would it help when parking your RV to pick a site that the awning faces south. It would help burn off the direct sunlight on the dark sides.
2014 Wildcat 327ck
07-20-2016, 11:05 AM
I just ordered this
Comes complete with ceiling grill
https://www.ebay.com/itm/262457773964
07-20-2016, 02:30 PM
I've often wondered why RV air conditioners suck. Is it merely a tonnage issue, or is there more to the story?
